Question about Sony PDW-510 Camcorder
My Sony PDW-1500 Professional Disc Recorder (9DVCAM XDCAM) has developed the following fault displaying the error code "error 03-354" on the display screen.
3 Suggested Answers
SOURCE: Hi when i put the
03-354
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
Posted on Nov 09, 2011
dalehendel
  • 12 Answers
You can't use 50 GB discs in your camera. Insert a 23 GB disc and the error will clear.
Posted on Nov 04, 2013
Sony camcorder xdcam pdw-700 error codes 91-225
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
Feb 22, 2017 | Sony Office Equipment & Supplies
What is the solution to error 02-F37
No mvement is detected in the ND filter initial operation check of OP (OP0).Problem with laser.
Jun 24, 2014 | Sony PDW-HD1500 XDCAM HD Compact Deck...
SONY PDW-F355 error code 02 F 37
There was a firmware update (2.01) to correct this. May 14, 2012
Servo drive function is improved as follows.
The servo drive is now adjusted correctly, and the adjustment no longer results in offset values from characteristic variations in the alignment disc (PFD23A-RS).
Previously, when not adjusted correctly, inserted discs were not recognized, DRV ADJ Err (Error 6F-E00/6F-E80) appeared, and the unit stopped operating.
Apr 15, 2013 | Sony PDW-F355 DV Camcorder
Hi we have a PDW-HD1500 with an error message/code of Error02-FB7. Thanks.
Error code 02-FB7 means "No movement is detected in the ND filter initial operation check of OP (OP1)", meaning the filter that regulates the ammount of light coming out of the laser diode is faulty. It does not say what the problem is, only that there is one.
Swapping the OP (Optical block assembly (the laser thingy on the two rails in the ODD)) for a new one will certainly fix this problem. just make sure you don't touch the lens!
Jan 02, 2013 | Sony PDW-HD1500 XDCAM HD Compact Deck...
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03-354
Sep 21, 2011 | Sony PDW-510 Camcorder
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: kaltpro@gmail.com
Jan 18, 2011 | Sony PDW-510 Camcorder
When trying to import XDCAM (SD) clips into Final Cut Pro, the xdcam transfer software is first coming up with the error - ERROR SCANNING DEVICE - The mediapro.xml file cannot be found. This is most likely...
The Sony XDCAM EX series camcorder including Sony PMW-EX1, Sony PMW-EX1R, Sony PMW-EX3 and Sony PMW-350. For FCP users who are facing the same issue to import Sony XDCAM EX MP4 to FCP X, there are 2 solutions for you to fix the problems.
The first solution is using third-party Sony XDCAM Transfer software. Prior to importing Sony XDCAM EX MP4 with with XDCAM Transfer, you may use the Sony XDCAM EX Clip Browse to first copy the SxS-based media to local storage. Then you can ingest MPEG-4 wrapped XDCAM-EX media to QuickTime-wrapped media with XDCAM Transfer application on your scratch disk. Then you can simply choose the XDCAM EX Easy Setup that corresponds to your footage and edit as you would with any other native format in Final Cut Pro.
If the first solution is too complicated for you or you encounter some unsolvable problem when adopting the first method. A much simple but reliable alternative solution is recommended to you. You can use a third-party application to transcode Sony XDCAM EX MP4 to FCP X best native compatible editing codec -Apple Prores, which is specially developed by Apple for fast and fluid post-production editing workflow in Final Cut Pro X.
http://www.multipelife.com/transcode-xdcam-ex-to-prores-for-fcp-x.html
Apr 12, 2017 | Sony Televison & Video
Sony PDW-510 Camcorder Logo
452 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
