Question about Sears Craftsman 46 in Mulching Tractor Blade
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
    New Friend:
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Posted on Sep 21, 2015
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
You need to get down on the ground and have a look at why it is not turning left. Its as simple as that. A repair will not tell why it is not turning left. Good luck.
Posted on Mar 26, 2009
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for a Sears Craftsman II 12
http://www.searspartsdirect.com
Go to the above address, type in your model number
917.257280 just like this with a dot not a dash it will locate the tractor for you, go to the list on the left side of the page and select >>38" mower<< at the bottom of the Sub-components list and it will show you a picture of how it looks installed as well as all associated parts
Posted on Oct 03, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 376 Answers
SOURCE: We have a Sears Craftsman riding mower 917.258671
The steering assembly your mower has is very difficult to repair. Thank God they no longer make that type. Forget about trying to tighten that screw, it won't solve your problem anyway. Believe me, you should take it to a repair shop.
Posted on Nov 05, 2009
How to fix the toe out problem on my 2010 craftsman lawnmower?
Your gonna have steering rods called tie rods going to each spindle (wheel). Most lawnmowers dont have threaded tie rod ends where you can unbolt it and turn it in or out to achieve perfect alighnment. If its a larger expensive tractor you will find this and its a easy fix but most likely you just have a bend in one of the tie rods or on some cheaper models there could be a plastic bushing warn out causeing play in the front end.( Being able to slightly turn wheels without steering wheel turning) I would most likely say you have a bent steering rod or two... GoodLuck Ken
Aug 04, 2012 | Craftsman Garden
Lawnmower tractor turns more to the left then to the rightt
look at the plastic connector where the steering shaft meets the main gear the plastic wears out and the gears jump out of time its a $15 part at sears parts online
May 25, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 42" craftsman tractor... when you turn all the way to left the wheels get stuck... can I adjust anything?
What happens when you turn right? Does it turn as sharp as it used to? Almost sounds like the steering gear teeth have slipped and now it is steering to far to the left. You'll have to check the steering sector gears at the bottom of the steering column.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My steering wheel will not turn towards the right. it sounds like it stripping gears. How do i repair it?
raise the hood and follow the steering wheel shaft down ti the gears. u either have gears stripped or a worn out bushing.get parts and replace or have a lawnmower repair person do it.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears craftsman lawnmower has steering linkage poping out of socket
It should have a keeper on the top or your linkage is bent, how does it compair to the other side or is this the linkage under the steering wheel?
Oct 22, 2009 | Craftsman Garden
Its a sears model 3000, the steering gear thats
It wont hurt to try to straighten it if you can tell where the problem is. My guess is that it is worn out and should be replaced. The big problem will be locating the parts. If the unit is 10 years old or older you might have a problem.
Sep 13, 2009 | Craftsman Garden
Won't turn right
Had this on my riding mower. The steering rod going to the wheels from the steering assembly was bent. Take it off and straighten it and re-install.
Aug 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My mower will steer left but when i try to steer right just click
sounds like your sector gear and pinion are at fault go to sears.com to parts and enter your mod# you gave. if this is the problem could be labor intensive to repair
May 25, 2009 | Garden
Sears Craftsman 46 in Mulching Tractor Blade Logo
248 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Matt Olenzek
Matt Olenzek
Are you a Sears Garden Expert? Answer questions, earn points and help others
