Question about Sewing Machines
The tension seems to be loopy on the underneath of the fabric just can't get it right
  • 415 Answers
Tighten the top tension. To check the bobbin tension take the bobbin out and dangle it by the thread like you would hold a yo yo. A gentle flick of the wrist should cause the bobbin to drop down some but not just spin out to the floor, ie there should be some tension. If it hits the floor it is too loose. But if it doesn't release, fall, some it is too tight.
When you stitch a broad zig zag if the tension is correct it will look identical on the top as it does on the bottom. If it is smaller on the top then the bobbin is too tight. If it is smaller on the bottom than the top tension is too tight etc.
Posted on Mar 26, 2011
Baby lock quest plus and the bobbin thread is all loopy. I have done everything. I believe it is in tension discs. When I move it to 8 or 9 it sews ok. When I sew faster it seems to start looping.
Is it really the bobbin thread that is loopy--not the top thread looping under the fabric? If this is the case, it is called bird nesting. (problems appearing under the fabric are usually a top thread issue, problems on top of the fabric usually indicate a bobbin issue)
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to loosen the top tension to get it where it should be. The two threads should meet in the middle of the fabric.
If the bobbin thread is still too loose, then an adjustment may be needed to its tension.
Understanding Thread Tension Threads
Feb 10, 2018 | Baby Lock Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
What would a typical tension number be for a cotton fabric? mine is loopy or tight right now
you didn't mention the name and model number of the sewing machine or serger... is the loopy thread on top or bottom? when is the thread tight? what type of cotton fabric,, solid cotton--polyster cotton? normally mine stays on 4 or 5 --depends on fabric I'm sewing..
Dec 15, 2014 | Sewing Machines
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Dec 08, 2014 | Sewing Machines
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
The thread loops underneath the fabric. Singer 132Q
loopy underneath means upper threading is wrong or no tension
Aug 12, 2009 | Singer Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
