Question about Foxconn G41MX-F 2.0 Socket 775 Celeron D-Core2 Duo-Core2 Quad-Pentium Dual Core Intel G41 Micro ATX ... (MBFXG41MXF20) Motherboard
I got the foxconn G4M1MX-F 2.0 and i put it into my computer... but the computer turns on but nothing loads... screen dose not turn on or anything any ideas.....
    Guru:
  • 433 Answers
If your proccesor bus 533 its didnt work must be bus 800 plz send cpu info to can help thank you
Posted on Mar 26, 2011
  • 902 Answers
Do you hear any bios beeps at all? is the cpu fan running? and make sure you got the power coming from the power button hooked into the right header on the mobo
Locked and can'nt do anything
I put in lock on my galaxy & now all it dose is keep showing when I put password in Ice cream ads over & over & only back button shows over & over can't do nothing
Sep 08, 2013 | Samsung Galaxy Tab 2 7.0
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Just put a computer together with the Foxconn M61PMV board. It loads up with the Foxconn logo, all the parts are in the right places, and it works fine. However, I cannot input at all with a keyboard (USB...
I would assume you've tried different ports and different keyboards.
If you have, I'd contact the reseller and RMA the board.
There's really nothing you can do with a board that won't go into the setup.
Just for kicks, remove the CMOS battery on the board before you email/call the reseller.
Mar 16, 2011 | Foxconn M61PMV Motherboard
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
Feb 10, 2011 | Foxconn A88GMX AM3 AMD 880G HDMI Micro ATX...
I bought Foxconn 755A01-6EKRS Motherboard for my HP pc replacement. i install my AGP VsionTek x1300 graphic card and turn it on and nothing show up on screen...then i put the graphic card back to my old HP...
Your new Foxconn motherboard Primary Graphics Adapter settings in set to onboard vga that is why there is no display in your monitor. Do not install yet your agp video card. Use first the onboard vga of the motherboard.
Power up your computer and go to the BIOS settings. Locate in bios about the Primary Graphics Adapter settings and then select AGP. Save changes and the exit. Turn off your computer and now install the agp video card.
Dec 16, 2009 | Foxconn 755A01-6EKRS Motherboard
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what happens.how many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
Foxconn 600A01-6LRS FANS START BUT NOTHING ON screen
Does your video card suit the motherboard they have different ratings
2X 4X 8X 16X if yours is a 16X and you fit to any lower number it will not work this is for both AGP and PCI-E
Aug 09, 2008 | Foxconn MB KT600 600A01-6LRS Motherboard
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
No response, no turn-on, dead player! help!
Same thing just happened to my M260, did you ever get an answer? Thanks, Jeff. Problem: No response, no turn-on, dead player! help!by mtx410 on Aug 28, 2006 I was loading files, when the transfer locked up, and the computer threw an error. i couldn't do anything but unplug the player! After I did this, i tried plugging it back in, and half of the world "initializing" popped up on the screen, the first half was missing! it did not do anything more. so i unplugged it again. Now when I plug it in, nothing happens. The computer recognizes that new hardware is plugged in, but cannot recognize what it is. Nothing comes on the mp3 player's screen. It will not power up when i hit the power button. It has no response, it acts like there is no battery in it. I have taken the battery out, and put it back in. Nothing happens when any of the buttons are pressed, or when it is plugged into the computer. Is there anything I can do to get this thing working again! It is the M260 if that matters.
Aug 28, 2006 | SanDisk Sansa m200 (2 GB) MP3 Player
Foxconn G41MX-F 2.0 Socket 775 Celeron D-Core2 Duo-Core2 Quad-Pentium Dual Core Intel G41 Micro ATX ... (MBFXG41MXF20) Motherboard Logo
139 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
