Question about Kenmore Dishwashers
Intake water to an old Kenmore run very slow. Is there a filter inside the dishwasher that can be cleaned? Or any other part that needs cleaning?
    Scholar:
  • 116 Answers
If your talking about when its filling at the beginning of the cycle, there is an inlet water valve on the bottom of the dishwasher, not sure if you can clean these out alot of them are sealed, and would require you to replace it. The water line coming into the dishwasher connects to this valve, you can take the valve off and look down inside to see if its possible to clean but most the time these need replaced. They cost around $50-75.00.
Sean
Posted on Mar 26, 2011
Frigidaire/electrolux dishwasher not cleaning top rack
There is a circulating pump that takes water from the bottom and pushes it to the top spinner. Most likely that pump is clogged or needs to be replaced. Replacement is a somewhat involved repair that requires removal of the lower pump assembly. It can be done DIY if you are comfortable with disconnecting a/c power to the unit, removing the unit and making tight hose re-connections. Before you do that - maybe check the intake for clogs that may be slowing the water flow. Have you routinely cleaned the bottom intake? (Most likely not ...) You can start by cleaning the bottom intake by usually removing the lower spin arm, then take out the catch ring and check for obstructions. The spin arm rests on a cap that can be removed to then remove the screen assembly. Be careful not to force the part in the wrong direction - with these you usually turn the spin cap right to unlock from the base. Then you can access the intake area - be careful as there are probably blades inside the intake that work as the disposal grinder. Remove the soap scum and buildup on all removal parts with a simple sponge and baking soda scrub. Do not attempt to run the machine with parts removed.
Sep 05, 2014 | Frigidaire Electrolux EIDW6105GS 24 Fully...
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
The dishwasher detergent dispenser is gumming up and dishes are not as clean as they use to get.
Purchase a dishwasher cleaner tablet(s)
You may need to remove and back flush the spray arms
Ensure there is nothing blocking the water intake in the bottom
Your issues seems to be low water flow. These are the simple and inexpensive solutions try the first.
Sep 21, 2017 | Kenmore Dishwashers
Dishwasher not cleaning food is still on dishes
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
Oct 28, 2010 | Kenmore Dishwashers
Food residue is building up on my dishes. i have put CLR through it to clean it out. is there something else i need to do
Oct 03, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
No matter what cycle the dishwasher runs, the glasses always have stuff stuck to them. have run a couple of different washer cleaners through it but no luck .heating elements are fine. any suggestions
Sep 14, 2010 | Kenmore Dishwashers
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
I want to take off the bottom screen to clean debris. I have taken screws out, how do I remove the screen?
You may to remove more screws from around the complete bottom part of your dishwasher. Have you tried to add Dishwasher Magic to clean the grit and grime out first? Or perhaps if you can't find Dishwasher Magic, we started using Tang Orange Juice powder before the days of the modern prodcuts. The citrus in the powder eats all the tiny food particles away.
In either case, empty all the dishes from the inside, add a cup of Tand or follow the instruction on the box of DW Magic. Run your d/w through a complete cycle.
This should clean your dishwasher out.
Hope this solves your problem.
You may contact us at;
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with any questions or comments. Thanks, Ella
Nov 13, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Water goes in very slow. Cleaned the intake filter where the hoses connect.IS the valve worn out to where it does not open all the way?
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Oct 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
67 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
