Question about Panasonic Viera TH-42PX80U Plasma TV
What causes a patchy screen when tv is off It looks like its got a pigmentation problem lol
  • 158 Answers
It sounds like an Image retention which is fairly common for plasma panels. dont worry about it its normal. just avoid static images (like the network logo) for the first 100 hours and you will be fine. also stay away from dynamic mode for the first 100 hours.
post a comment if you need more clarifications, thanks
Posted on Mar 26, 2011
Picture is all patchy
Many things can cause this depending on the set. If it is an LCD or LED set it could be the T-Con board, cracked screen or ribbon cables breaking loose across the top or bottom edge of the screen. Sometimes you can squeeze along the top or bottom of the frame around the screen and it will clear up so you can verify that as the cause. If it is a plasma set it could be the Y Sustain board.
Oct 19, 2014 | Televison & Video
Patchy on screen and can't read
Video issues like you describe can only be two things in hardware either a Video card, or display. Patchy display is typically a bad display that has been dropped or damaged. On the software side a new driver or update can cause image problems but typically it will be no display vs. patchy display.
Feb 26, 2014 | Lenovo Computers & Internet
How do u fix green pigmentation on a toshiba 32C110U 32 LCD TV
It all depends on if the pigmentation is permanent or due to static voltage within the circuit , in the RF circuit or fault in circuit.Use a cleaner to wipe and check if this changes , also check using the DVD and if the picture is clear then check your cable.
Mar 11, 2012 | Toshiba 32C110U 32 in. LCD TV
Hi, I have an Hitachi 42PD9700 plasma TV. When the TV is off you can see a mottled/patchy area on the top right hand side of the screen (this is still visible when the TV is on if you look closely). This...
Same problem. Gray clouds INSIDE the external (plexi)glass of the screen.
I guess either:
1 - Screen collection dust or some electrostatic phenomenon.
or
2 - Some coating peeling off.
1 may be solved by dismounting and cleaning.
Any solution you know about ?
Sep 22, 2011 | Hitachi Televison & Video
My psp was dropped and know it wont turn on the screen. what can be wrong?
Greetings,
Most likely, you have destroyed the color pigments that are located in the screen. These pigments are necessary for the screen to work. You will need to replace the screen. Thank you for using FixYa! =)
Nov 21, 2010 | Sony Video Game Consoles & Games
Colour change on tevion tv
is all the screen the same colour or is it patchy. It could be the degausing cerquet (if patchy). Or maybe just to be degaused with a degausing coil.
Jun 01, 2010 | Televison & Video
43'' SAMSONG FLAT SCREEN. SHADOWS RADOMLY APPEAR
Is your tv a plasma tv or an lcd tv? When you say shadow, do yo mean a band across or down the screen, or is it a patchy shadow?
Mar 17, 2010 | Televison & Video
No red pigment on Screen
Pull back to TV turn on watch to see if all 3 tubes are lighting up if Red is lighting but no red CK projection Fuild in Tube, look down into lenses if you cannot see pictue clearly then Fuild is Bad.
Sep 21, 2009 | Panasonic Televison & Video
Grid pattern on Canon MP760 test print is patchy and cleaning process does not fix it.
You can try to remove the print head and ink cartridges.
Soak the head in an ammonia10-20% solution with warm water for 30-45 min.
Dry the head completely and re-install.Now run your grid patter,
It sonds like(from the grid reference)that only the black is clogging.This is a pigmented ink and tend to dry if not used for months at a time.
Jun 20, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Dash panel lcd display patchy
HI,YOU WILL HAVE TO SEND THE CLUSTER TO A ELECTRONICS SHOP TO HAVE THE LCD SCREEN REPLACED,ANDY
Mar 14, 2009 | 2005 Audi A3
Panasonic Viera TH-42PX80U Plasma TV Logo
123 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
