Question about HTC G1
If your reset your g1 to factory settings dose anything get erased
  • rqjeffrey Mar 26, 2011
    i need to know if my contacts or text messages will be erased but thank you for the help
  • 902 Answers
Any programs and things you added to your phone will be erased.
Posted on Mar 26, 2011
  • brian shevack Mar 26, 2011
    contacts wont if you save them to sim but txts yes
    President:
  • 1,623 Answers
Everything is erased
  • Martin Murray Mar 26, 2011
    the term EVERYTHING will usually include contacts and messages
Tip
How To Fix Your G1 Stuck On The Android Logo
First, if you haven't already tried it, please remove and re-insert the battery.<br /><br /><b>The following method erases all data from the handset's memory, and sets it back to original factory settings. It does not erase the sim card or the memory card. </b><br /><br />There are two ways to perform a Factory Data Reset, also known as a master reset or hard reset. Since we cannot boot into the device, we will perform a hard reset:<br /> <ol> <li>The device must be powered OFF to perform this reset.<br /><b>Note: </b>If the device is not responsive and does not turn off, remove the battery and re-insert it. </li> <li>Press and hold the <b>Home</b> button (picture of a house on it) and the <b>Power</b> button (the red hang-up button) at the same time.</li> <li>Keep holding <b>Home </b>and <b>Power </b>together for at least 25 seconds, even if the "Startup" screen appears.</li> <li>Release the keys when you see a black screen with a warning sign.<br /></li> <li>Slide the keyboard open.</li> <li>As a shortcut, press <b>ALT+W</b> to factory reset the device. If this does not work, continue with the below steps.</li> <li>Press <b>ALT+L</b>.<br /></li> <li>Press <b>Alt+W</b> for 'wipe data/factory reset'.</li> <li>Press the <b>Home</b> + <b>Back</b> key.<br /></li></ol>
on Jan 25, 2011 | Cell Phones
Tip
How to hard reset or factory reset T-Mobile G1 phone
Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory.
Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
  1. Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
  2. Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
  3. Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
  4. After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
  5. Next, press 'Alt+W' key (to factory reset it)
  6. Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
  7. The reset is complete.
on Feb 25, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Factory reset setup ERASED EVERYTHING NOW CANT GET TO ANYTHING
Go into settings and search all channels will have to be downloaded again.
Jul 18, 2014 | NetGear NTV300SL NeoTV Max Streaming...
How to factory reset a irulu tablet
It should be in your set
Jul 12, 2014 | HTC G1
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i...
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Jul 27, 2011 | HTC G1
Why won't my g1 show anything when it powers up
Keepon holding the Home button and press the power button. Check if you are able to see the recovery console. If so Select "Wipe to factory setting", that will reset the phone. Turn off and then restart the phone. It should take care of the issue
Thanks and regards,
Anil.B.R
Oct 24, 2010 | T-Mobile G1 Android HTC Google Smartphone...
G1 hard reset prob
if the problem you are having is figuring out how to do a hard reset..this is what you have to do.
go to your settings menu scroll down to sd card & phone storage go to factory reset data read what it describes and if that is what you want click on reset phone
this will reset your phone to factory default.
Oct 13, 2009 | HTC G1 Smartphone
How do i reset my g1
  1. Power off the G1
  2. Hold Home Key + End key for 20 seconds or until you see a "triangle with an exclamation point and a picture of the G1"
  3. Open the keyboard and hit Alt+W
  4. Restored!
Oct 01, 2009 | HTC G1
G1 SD
if reemoving and reinserting the card doesnt help, youll need to have it reformatted....
do this by connecting your phone to the pc and opening your MY COMPUTER icon > right click REMOVABLE STORAGE/DISK > select FORMAT
**if your computer says something like 'no disk available' try disconnecting the device and select MENU > SETTINGS > SD CARD AND PHONE STORAGE > make sure the check bos for 'USE FOR USB STORAGE' is checked****
after that, set the 'file systems' as FAT32 > select START > read the warning > press OK > once complete, disconnect from the pc and try again!
IF that doesnt work, try to test the sd card in another phone to see if the sd card itself is the problem. if you still have the issue but the sd card works, go ahead and reset the phone.
MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
Nov 17, 2008 | HTC G1
HTC G1 Logo
47 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
