Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
If i push alpha key for passward it's does not work at all...
    Problem Solver:
  • 16 Answers
If you don't see it on the screen thats because it's changing the number into a letter (1+alpha,alpha=Z).
If the key is not working it needs a new key pad.
Posted on Apr 25, 2011
How to reboot VX670.
Push F2 and F4 at the same time.
Enter the system password z66831. (You get the z by pressing keys 1, alpha, alpha) choose restart. Opionally remove the power cord then press and hold the red cancel key for ten seconds. Wait for the shut down. Then press and hold the green enter button until it turns back on.
What I do is not reccomended. Remove the battery and the power cable. Then replace the battery and power cable.
Jun 09, 2014 | Retail Supplies
Key working alpha
The alpha key activates the alphabet keyboard and a few extra symbols. To access the MATH menu and the ToFrac command, press the key below the ALPHA key. The key is marked with MATH.
On the TI84PLUS with the newer operating systems (version2.5x), the APLHA key opens up a few functionalities. That is not available on the TI 83Plus.
Sep 02, 2013 | Texas Instruments TI-83 Plus Calculator
Alpha keyboard not working
if usb keyboard and local keyboard aren't working i'd check to see if you have a fuction key pressed that disables you from using the keyboard, try restarting, if it solves the issue it was a FN key if not, problems deeper and you may want to look at hardware diagnostics
Apr 17, 2013 | Acer Aspire Computers & Internet
I forgot my e1000's passward and lost wireless connection. How do I get passward for it?
you will need to access the setup page of the router and check the wireless settings manually. On the wireless tab you will find the WEP WPA network key
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Alpha key not recognized when pushed
When the ALPHA key is pushed the cursor shows an A. Press one of the keys that has the same color as the ALPHA key (A,B,C,...X,Y,Z).
If you have the MathPrint OS, the ALPHA F1/F2/F3/F4 sequence activates shortcuts to newe features (fractions, logab, sums etc..)
Sep 16, 2011 | Texas Instruments TI-84 Plus Calculator
How do you solve log problems on your calculator
I have no idea what type of log problems you want to solve. It does help to know what you have in mind. To type in the log function log(, you have two ways:
1. Use the keyboard to type it in on the command line APLHA L, ALPHA o, ALPHA g followed by opening parenthesis. Or if you can LOCK the alpha keyboard, lock it and press the keys corresponding to the letters l, o, and g.
2. Press [Diamond key] [7]
The last trick works on the TI92 and TI Voyage 200 PLT which have a full fledged keyboard. Try it anyway, if that does not work you can still use the ALPHA keyboard.
Jul 26, 2011 | Texas Instruments TI-89 Calculator
How do I the ALPHA f1 function menu to appear so I can enter fractions
Hi...
You can access F1 by
  1. Press and Release "ALPHA" Key
  2. Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example:
pressing UP and DOWN keys navigates the screen up and down
if we press ALPHA key and then UP/DOWN key, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions.
if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
Mar 18, 2011 | Texas Instruments TI-84 Plus Calculator
Casio fx-300es. How do you enter a variable? what button do you press to represent x in x+7=14 or any other problem with a variable. Everyone has a ti 84 and they have a button for x.
You have a way to enter the Variables A, B,C,D, Y and X.
Use the ALPHA key
For A use ALPHA change sign key (-), below the Fraction Template.
For B use ALPHA (degree ' ")
For C use ALPHA (HYP)
For D use ALPHA (SIN)
For X use ALPHA right )
For Y use , ALPHA (S-D) key
For =, use ALPHA and the key below the SHIFT key. May be marked CALC. The = is in the same color as the ALPHA on calculator. It should be to the upper right side of a key.
(I have an FX-991ES that is compatible with the FX-300ES, but since I do not have a picture of the FX-300ES calculator I cannot be more specific than I have been, lest I mislead you.)
Apr 09, 2010 | Casio fx-300ES Calculator
CASIO fx-300ES
Storing
  1. To store numerical values in the variables A,B,C,D,X,Y and M you use the [SHIFT][RCL] key combination to access the (STOre) function.
  2. In what follows [ key] is the physical key and (key) is the SHIFTED key
  3. ex: store the value 13 in variable A
  4. 13 [SHIFT][RCL] (STORE) [(-)] (A)
  5. The calculator displays 13 --> A on top line and 13.000.. on bottom line.
Recalling
  • To recall a value stored in a variable ex: recall value stored in variable A
  • Press [RCL][(-)] (A)
  • Calculator displays A on top line and 13 on bottom line.
If you need to use the variables A,B,C,D,X,Y, and the = sign to create an expression to be solved with the solve( function you must press the [ALPHA] key
=: [ALPHA] [CALC](=)
A: [ALPHA][(-)] (A)
B: [ALPHA][ 0 ' "] (B)
X: [ALPHA][ ) ] (X)
Y:[ALPHA][S<=>D] (Y)
etc.
Jan 05, 2010 | Casio fx-300ES Calculator
Keyboard Fn appears to be stuck
check to see if the num lock key is on
Nov 22, 2008 | Dell Inspiron 1501 Notebook
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
241 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
