Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
I reconnected the the control panel and the display works but the oven does not heat. No error codes. What would be the next step?
  • 1 more comment
  • thelakeys Mar 26, 2011
    I could not understand the reply and would like a second persons viewpoint. If there is another relay then where is it and what does it look like? Is there a part number? Is it something that just needs to re-soldered? Etc. Help means help.
  • thelakeys Mar 27, 2011
    I tested the probe with meter and it checked out fine even to the control board. But oven still won't heat. Is this a situation that just requires a completely new stove/oven? I'm at a loss on what or how to check the control panel on back. Control display still reads fine and I can enter bake and temp but temp just stays at 100 degrees and elements never heat up. Any advice will be a big help and thanks a bunch for stepping in and helping me this far.
  • thelakeys Mar 28, 2011
    Solution was helpful but decided to go ahead and call a service tech since next steps require performing voltage checks with power on.
  • Jenn-Air Master
  • 19,396 Answers
Hi.
I do not think that the "relay" is causing the problem. The oven has a bake/broil relay board, but when the problem the main control should return error .
If the oven does not bake or broil, and there is power to panel, but no error code, it is usually the temperature probe. The probe is located inside the oven cavity, and it is held by screws. The part is tested by disconnecting its wiring and reading impedance (Ohms) at the probe contacts. A good probe will show continuity at room temperature. That means that the reading will not return open (Ohms infinity).
If the problem is not the probe, then check the relay board. The board is part nr.23 in the diagram below. Click on the picture to enlarge:
If probe and board are OK, then there is an intermittent wiring problem. Check wiring to probe and relay board.
Here all parts and diagrams for this range.
Regards.
Ginko.
Posted on Mar 26, 2011
  • Ginko
    Ginko Mar 27, 2011
    Hi.
    Unless you plan to get a new range, the oven is still repairable, but there is testing that must be done with power on. For safety reasons I must remind you that this must be done by a trained technician.
    There are only three parts that can be involved (4 counting wiring harness). The main control, the relay board, the temp probe.
    Testing is done reading volts at relay board (that is quite tricky), and volts out from timer. When on, the relay must have power from timer control, and must give out power to element. A good relay has two contacts with power when good.
    You can also do some testing with power off on elements and wiring harness (if problem is on both bake and broil elements is quite unlikely). In there read impedance and ensure that there is continuity. Double check the probe just in case.
    Check also the door switch if you have not done it yet. Read Ohms at switch contacts and in wiring harness. Ensure switch is opening and closing, and ensure that switch wiring harness has continuity between switch and timer board. Here the part: Door Lock Switch
    President:
  • 2,468 Answers
Then in the same area there is an oven relay that is controlled by the interface control panel you just re-installed,this board is called the "master" board that sends a signal to the relay to in- directly power the heating element and when you press an option on the control panel board you re-connected it will latch a main power relay on the board to send power,if this boards relay opens up on the high voltage/current side this relay may close,but if the relay has burned contacts(on this side) it wont send current to the heating element even if the controller says it is doing so
What does F6 error code for Whirlpool microwave model XCK4640802 mean
The F6 code is listed as a problem with the MW relay. Here are the testing steps from the technical literature. The relay that is mentioned is a part of the control so if the problem continues you will need to replace the control.
1. Unplug microwave oven or disconnect power.
2.Check the cable to Relay 4903.
3. Check to see if the relay (4903 on relay electronic control) contact has welded closed.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
6. If problem persists, unplug microwave oven or disconnect power.
7. Replace electronic control.
8. Replace all parts and panels before operating.
9. Plug in microwave oven or reconnect power.
Good luck.
Semper Fi,
Z
Feb 01, 2018 | Whirlpool Microwave Ovens
Flashing indicator light
follow the next steps and fix it. God bless you
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 06, 2013 | Dishwashers
F10 code on a Kenmore self-clean range model #970-6061
Your Kenmore oven has a built-in fault detector. When the oven detects an issue, the display screen on the control panel will flash a fault code. The F10 fault code on your Kenmore oven indicates that the thermal protector on your oven's control unit, or microcontroller (MCU), has overheated. If the MCU overheats, the computer stops all motor functions. Several items on your oven could cause the thermal protector to overheat. Therefore, you must troubleshoot the F10 code to determine why it appeared on your display panel. Instructions 1 Inspect the area around and behind the oven to ensure you did not place the oven next to a source of heat, such as a register vent or other appliance that becomes very hot. If this is the case, you must remove the oven from the heat source to prevent the issue from occurring again. 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears. 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
Aug 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How to shut off F10 alarm on Frigidaire Gallery oven?
follow the next steps and proceed with commong sense: God bless you
  • 2 Inspect the oven to ensure all vents on the oven are open and unblocked. This includes heat vents that vent to the outside of the home. Remove any clogs from the oven's venting and check to see if the code reappears.
  • 3 Inspect all of the wiring harnesses that connect to the MCU. Remove the back cover from the control panel with a screwdriver. Look for disconnected harnesses or any harnesses with black residue on them. This indicates an issue with the MCU. Remove the bolts that secure the MCU to the control panel housing and then replace the MCU with a new one. Reconnect all of the harnesses and retest.
  • Jul 27, 2012 | Frigidaire FGGS3045KF Stainless Steel Gas...
    Top oven temp display shows 4444
    Control panel needs to be replaced. It may also be an error code for the repairman.
    Jul 22, 2012 | Neff U1661 Double circotherm super...
    I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
    Hi Kent:
    F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
    Here is the actual tech manual instructions for that code:
    PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
    If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
    If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
    If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
    UI IS NOT DISPLAYING AM SOFTWARE VERSION:
    A. Unplug oven or disconnect power.
    B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
    - If they are not plugged in, plug in connectors and go to step F.
    - If they are plugged in, go to step C.
    C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
    - Make sure wires are not cut or pinched.
    - If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
    D. Replace the appliance manager. Ensure all connectors are properly inserted.
    E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
    F. Replace all parts and panels before operating.
    G. Plug in oven or reconnect power.
    H. Observe for longer than 1 minute to determine if error has been repaired.
    I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
    - If no error occurs, cancel the cycle, the problem has been repaired.
    - If error occurs again, restart the troubleshooting procedure at step A.
    At step D, replace the lower oven user interface board if appliance manager has already been replaced.
    - If both are replaced the problem has been repaired.
    Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using Fixya, and have a nice day.
    Dec 10, 2011 | KitchenAid Washing Machines
    Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
    Below is the complete instruction sheet.
    You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
    manager.
    EEPROM VERSIONS.
    P2-5(UI). All the measurements made should be less than 5 ?. If any of
    these measurements exceeds 5 ?, go to step E.
    1 minute.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    May 22, 2011 | Ovens
    Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
    Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
    Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
    these are some other code error that will help you in case of next time.
    1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
    2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
    3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
    4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
    5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
    6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
    "F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
    Take care.
    May 11, 2010 | Microwave Ovens
    Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
    Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
    My step Dad's whirlpool, electric, self cleaning oven will not heat up at all. Model # RBS245PD012. The power went out for just a few minutes so he was resetting the clock. An error code E3-F1 is on...
    Hey there-
    He ended up calling a repair tech.. He came out and ended up replacing the whole control panel.
    My step Dad says it works fine now and the clock is a lot brighter on the display than it was before, so maybe it was slowly going out then finally just gave in. ?? Thanks for checking in though.
    Oct 06, 2008 | Whirlpool RBS245PD Electric Single Oven
    Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
    250 people viewed this question
    Top Jenn-Air Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Sal De
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
