Question about Baby Trend Flex-Loc Infant Car Seat - Silverado
Handle is stuck in the carry position--Can it be fixed?
  • 396 Answers
These car seats seem to have a problem in the release mechanism that
lets the handle move. We have found that lifting the handle a bit as you press
the releases can help. Try pulling toward the front of the car seat, then pressing
the release buttons. If all else fails, call Baby Trend and complain. It just might
get you a replacement if you can prove it is a danger to the child in the seat.
Baby Trend, Inc.,
1607 S. Campus Avenue, Ontario, CA 91761
By Phone: 1-800-328-7363
Posted on Mar 26, 2011
Wondering if there is a special way to move handle from upright position on the carry me near bassinet?
They're buttons hidden right at the base of the handle on the inside under the fabric. just push those down. I had a hell of a time myself...lol.
Mar 25, 2011 | The First Years Carry-Me-Near 3-in-1...
Have a 1998 Jimmy, the driver door is stuck in the close position and can not close the door. The handle seems to be working properly; inside handle moves the cable that permits the door to close and...
with the door open see if latch is stuck in close position . If so hold handle open and pry with screwdriver to open latch ..If that works latch needs to be lubed for smooth operation
Feb 17, 2011 | 1998 GMC Jimmy
After winding 2 new bobbins, the LED screen remains showing the bobin being wound, even when bobin is removed from spindle and spindle is mived back to the left.
The front panel circuit board has a microswitch which is activated mechanically when the bobbinwinder is moved to the winding position. The error is most likely with the microswitch stuck in one position. The remedy requires you to have moderate mechanical aptitude. The best thing to do would be to take it to your dealer for repair. If you want to try to do it yourself, here you go:
  • DO NOT REMOVE THE SCREW HOLDING THE SMALL PLASTIC BOBBINWINDER STOP NEXT TO THE BOBBINWINDER SPINDLE
  • Open the top lid and, with a straight slotted screwdriver, remove the two large silver screws
  • Close the lid and raise the handle into the carry position
  • Loosen, but don't remove, the small phillips screw underneath where the right side of the handle rests
  • Pull the top of the right side cover over slightly
  • Remove the small phillips screw underneath where the left side of the handle rests
  • With the handle up in the carry position and the lid closed, lift the entire top cover from the left side first, exposing where the handle attaches underneath
  • Carefully bend the lower part of the handle to the right and detach it from its mount
  • Remove the top cover and handle
  • With the top cover removed, you can see the bobbinwinder arm make contact with the microswitch
  • If you are extremely careful to not touch the circuit board with your bare fingers or with a metal object, you can manually press the microswitch to see if it works
  • The plastic microswitch "button" may have become detached
  • The "spring" on the end of the bobbinwinder arm may have become bent
  • Don't remove the bobbinwinder assembly
Nov 09, 2010 | Janome Memory Craft 4900QC Mechanical...
Telescopic handle problem in swissgear lap top roller suitcase.
The problem area is inside the riveted fabric. You may have to destroy your Swiss Gear case in order to salvage it.
Nov 22, 2017 | Swiss Gear by Wenger Wenger Gear Granada...
How do i reattatch the sun canopy on the maxi cosi carbrio fix? mine didnt come with one so ive brought one just need to attatch it now x
hi maria10102..hope this helps..good luck!!!
The sun canopy is located in the rim of the shell.
• Place the carrying handle in the carrying position.
• Open the rim by pushing the button at the back under the rim and releasing it.
• The sun canopy is now visible in the opening
• Pull it out and place the ends of the sun canopy with the buttonholes over the hooks on the carrying
handle
• When storing the sun canopy, make sure you place it in the rim carefully and close the rim properly
http://www.instructions.maxi-cosi.com/download/cabriofix.pdf
Mar 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Where do I put the water.
1. Release the handle and lay the machine
handle back to access the tank.
2. Remove the tank from the base of the
machine by lifting the tank carry handle.
3. Carry like a bucket to the sink. Rotate the handle forward
to unlatch the lid. Lift off and set the lid aside.
4. Fill up the bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the bladder.
5. Replace the top of the tank by matching the
lid and tank edges. Handle must be in the
forward position in order to replace lid. Rotate
Note: Remember to secure the lid and test to make
sure it is secure before picking up the Tank.
6. Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
You can download the manual from the Bissell website www.bissell.com
Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
make sure it is secure before picking up the Tank.
6.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
Note: If bottle leaks, check for proper positioning
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Baby Trend Flex-Loc Infant Car Seat - Silverado Logo
295 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
ray gallant
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
