I have a Sony Vaio thats from 2005 that is running XP. I need a new video card according to the pc shop after a diagnostic check, there was a warning "device driver got stuck in infinite loop". The video card currently in it is a ASUS EAX 300LE-A334C rev1.01. I mostly use the PC to search the internet and sometimes watch videos online. I don't use it for any gaming. Could you recommend a video card that I could replace it with that is somewhat affordable?
    Guru:
  • 433 Answers
Vaga card xfx....geforce
Posted on Mar 26, 2011
My computer has lost it"audio driver and it"s orignal window has been defected.
Posted on Mar 27, 2011
How to run diagnostic in sony vaio
start up in safe mode. if that doesn't work then i can do the diagnostic for you. your motherboard or video card has went. Since sony computers integrate the hardware all u can do is send it to them no hardware swaps no upgrades do not pass go do not collect 200 dollars
Sep 07, 2012 | Sony VAIO Computers & Internet
Sony Vaio PCV -RS704 SD card reader is not working and i can't find the driver for it
Check the manufacturers website go to the driver and support add your model number or service tag located somewhere on your Sony Vaio then download what you need from there as it will give you a list of all drivers compatible with that system. I hope this helps.
Aug 31, 2012 | Sony VAIO PCV-RS704 512MB DDR PC-3200...
1 LONG BEEP 2 SHORT BEEPS
Does anything ever post to the screen when you press the power button? if not, it's your video card. The links below are for 1 long and 2 short and they say it's the video card. I've heard that Sony extended the warranty on some models so you might want to go to their website and check yours or in a google search type: Sony GPU Extended Warranty. I did and I see they extended it from one to three years. They have the faulty Nvidia Graphics Card which was a major problem for many manufacturers.
Beep Code Links Below:
http://www.biosbeeps.com/sony-vaio-bios-beep-codes.html
http://www.techsupportforum.com/forums/f108/sony-vaio-vgn-ar51-beep-codes-614124.html
Extended 3 Year Warranty for Defective Nvidia Graphics Card links below:
http://apcmag.com/sony-vaio-notebooks-suffer-from-faulty-nvidia-gpus.htm
http://www.slipperybrick.com/2009/08/sony-warns-laptop-owners-of-defective-nvidia-gpus/
May 16, 2012 | Sony Computers & Internet
Are there any video cards that you can use to upgrade the 530g? I have seen posts that the power supply is an issue. If it is possible is it a matter of installing the card and disabling the onboard...
Your pc has a special graphics expansion port - AGP x8
You can insert any graphics cards which will fit the port. Check carefully, there are quite a few different types of graphics port.
Once inserted, boot up the PC, and insert the disk you should get with the card, it will have all the relevant drivers.
There should be no need to alter the bios settings, the new card will be identified by the boot process.
If power supply does become an issue, you will need to upgrade the PSU (Power Supply Unit).
Apr 26, 2011 | Sony VAIO PCV-RS530G PC Desktop
What video card comes with this computer?
Intel® 845GV Integrated Graphics
64MB max. Dynamically Shared Graphics Memory
Jan 02, 2011 | Sony VAIO PCV-RS310 PC Desktop
Can anybody help me with my krybord semes too be in t9 mode please
The VAIO Hardware Diagnostics utility can be used to perform various tests to ensure the computer is working properly and diagnose hardware issues when they occur. Follow this procedure to perform a Quick Test or Individual tests using this utility.
  1. Close all open programs. NOTE: If the VAIO Recovery Center application is already open, proceed with step 3.
  2. Open the VAIO Recovery Center application. NOTES:
    • If the VAIO Hardware Diagnostics window is already open, proceed with step 4.
    • The VAIO Recovery Center software can be accessed from the Start menu. Click the Start button, click the VAIO Recovery Center folder and then click VAIO Recovery Center .
    • If you cannot start the operating system, the VAIO Recovery Center software can be accessed by pressing the F10 key at the BIOS screen, but all the hardware component tests may not be available.
    • You also can access the VAIO Recovery Center software by booting the computer using the Recovery Discs. Insert Recovery Disc #1 and then restart the computer.
  3. In the VAIO Recovery Center window, under Choose a program , click VAIO Hardware Diagnostics .
  4. In the VAIO Hardware Diagnostics , click the Start button.
  5. On the Quick Test tab, click the Run Test button. NOTES:
    • To perform any of the individual tests available within the VAIO Hardware Diagnostics utility, click the Individual Test tab.
    • The Individual Test tab is only available when the VAIO Recovery Center is started from within the operating system.
    • Tests can be run on the following components: CPU, Memory, Video, Hard Disk Drive, CD-ROM, DVD-ROM, Network Adapter, USB, CF/PC Card, and Memory Stick.
    • The CPU, Memory, and Hard Disk Drive tests are performed during the Quick Test. The Video and CF/PC Card tests are also performed as part of the Quick Test when the VAIO Recovery Center is started from the desktop.
Dec 12, 2010 | Sony VAIO PCV-W1 PC Desktop
I have a sony vaio all in one pc model vgn-ls25e,when i intall it the drivers for the video card,when the pc restart the pc when blank,i have to go to recovery mode and unistall the video card drivers so...
there might be a driver conflict for the video card or it may need update.
click on this link http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGCLS25E
download the files under video that has 2 files
Apr 06, 2010 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
I have sony vaio vgn fs715 w but i have aproblem no sound with win 7 couldyou hel me
According to the website this model of VAIO does not support Windows 7. You should always consult the Microsoft website Upgrade Compatibility before upgrading OS. However, all hope is not lost. It might be possible to make the driver for XP work with your system. If you go to the Sony VAIO website, go to Support and download the XP drivers for the audio card to the desktop of your computer. Next, right click on the file and select Properties. Select the Compatibility tab, check the Run this program in Compatibility Mode for... box and select Windows XP with SP3. Also select Run this Program as an Administrator. Press Apply, run the program and you should be good to go.
If not, comment back and we can move further.
Good Luck,
NOLA Tech
Jan 28, 2010 | Sony VAIO VGN-FS715 Notebook
My sony vaio(VGC-LS21N)crashed,I took into a repair shop,the shop told me it was the video card,but being that its an all-in-one system the whole motherboard needs to be replaced.The problem is that its...
Without a copy of the diagnostics they did, if it is the video card then they are correct. The video card is a part of the main unit (motherboard). You would need to replace your motherboard, which can be costly.
An alternative is that if you have data you want to keep is that you can put the hard drive in an external hard drive enclosure and get another laptop.
Jan 14, 2010 | Sony VAIO VGC-LS21N PC Desktop
Video Card not recognized on PCV-RS410
Hi, have you check the status of the video card in the window device manager.
1. Right clicking My Computer icon on your desktop
2. Select Manage option from menu
3. Select Device Manager
Please verify if there is any yellow color exclamation appears on the left side of your new video card adaptor. If so you need to install a driver. I am assuming your pc is running window xp and video card adaptor is window xp compatible.
Hope this help.
Kam
Dec 10, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
Computers & Internet Logo
David Payne
David Payne
