Question about Frigidaire FGMV185K Microwave Oven
Is there a reset button on frigidaire microwaves. have already checked the circuit breakers but still not working
  • 490 Answers
Nope sure isnt, if it doesnt turn on you may have just blown either the load in fuse or the high voltage fuse down the bottom, remove the cover should be a couple screws round the outside and check fuses if you know how (MAKE SURE ITS UNPLUGGED FROM THE POWER FIRST) (NEVER START THE MICROWAVE WITHOUT THE METAL COVER ON AS THIS ACTS AS A RADIATION SHIELD)
Posted on May 04, 2011
My Frigidaire microwave model PLMV169DCB turn table stop working & wont heat up
Thank you for your inquiry, Justin!
From the information you have provided your Frigidaire microwave is not turning and it has stopped heating up. It sounds like the motor, magnetron, or control panel may need to be replaced inside of your microwave. This could also be a miscommunication within your microwave and a reset could help clear it out. You can reset your microwave by flipping the household circuit breaker off for at least ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Apr 06, 2015 | Frigidaire Microwave Ovens
How do I know if my frigidaire microwave oven is done.
Hey lizanne belmonte, thank you for your inquiry!
From what you have described your Frigidaire microwave is not allowing you to operate it. I would recommend performing a reset and you can do that by flipping the household circuit breaker for ten minutes by flipping the household circuit breaker. If that does not help to resolve your issue I would suggest having a professional come out to provide a proper diagnosis. Best of luck! -Matt
Dec 28, 2014 | Frigidaire Microwave Ovens
I have a frigidaire over the counter microwave and the turntable quit working
Good Afternoon Friend, I appreciate your post!
If the turntable of your Frigidaire microwave has stop working, often the possibilities include one of three culprits:
  • Power Supply
  • Turntable Turned Off
  • Turntable Support Damaged
I always recommend resetting your microwave first before reaching out to a professional. You can do so by unplugging your appliance or flipping the circuit breaker for about ten minutes and then turn on your microwave.
Best of luck!-Z
Sep 07, 2014 | Frigidaire Over-the-Range Microwave
Frigidaire microwave will not power on
Reset the unit's circuit breaker and if you still do not see any improvements, contact a professional service for diagnosis and repair.
Dec 26, 2012 | Frigidaire FMV156DC Microwave Oven
Will not heat food
HELLO.
The solution to make your microwave oven to be able to heat food is detailed given below.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks
Sep 20, 2011 | Frigidaire Microwave Ovens
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
I have bought a corrina microwave and it is not getting hot what could be the problem
HELLO.
Thanks
Sep 18, 2011 | Microwave Ovens
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Frigidaire FGMV185K Microwave Oven Logo
654 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
