Question about SanDisk Sansa e140 MP3 Player
Sansa e140 error
The battery trick didnt work for my sansa e140 keeps telling me to delete 4m from sansa system files.. it connects to pc but when u try to explore it, it says unaccesable and it pops up as two removable decives in my computer. plz help
  • 1 more comment
  • lydiechan Feb 21, 2009
    Same as above. The "flash memory" is the device itself and can't be replaced without purchase of new item. Any other ideas?
  • Anonymous Mar 10, 2009
    Same as above
  • Anonymous May 24, 2009
    Same.
  • 684 Answers
There is a Problem with the flash memory on the Mp3 player I would request u too replace it
Posted on Aug 03, 2008
MP3 is dead. Is there some trick to reboot?
Press and hold the power button (menu) in your e140 for about 30+ seconds. Now try powering on your Sansa.
If it doesn't work, press and hold select (center button) alongside pressing and holding power button. Probably this should work for you.
Dec 24, 2009 | SanDisk Sansa e140 MP3 Player
Hey can you tell me how to fi this problem my san disk e140 is telling me not enough memory cnnect to the pc delete 4m of songs for sansa system.i have tried everything it told me and it still do not work...
to solve the problem do the following things:
- download the firmware (http://www.sandisk.com/Retail/Default.aspx?CatID=1295)
- run firmware - SW
- FirmwareDownloader shows "Detecting"
- put oft the battery of the e140
- hold down the Power Button
- Connect the e140 to the PC
- FirmwareDownloader shows "Recovery mode ready"
- press start-Button
--> e140 works
Sep 28, 2008 | SanDisk Sansa e140 MP3 Player
Sansa
Reformat the player - see my "tips and tricks" on how to format an mp3 player for details
Jun 07, 2008 | SanDisk Sansa e250 MP3 Player
Can not access device neither directly nor via PC
I have the same frigging problem with mine. What's the solution?
Mar 19, 2008 | SanDisk Sansa e140 MP3 Player
No change is recognized in the playlist
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Nov 15, 2007 | SanDisk Sansa e140 MP3 Player
Detected by the pc but no changes are made
On the Mp3 player u will see a small slide switch which says Hold/Unhold try to slide that switch to the opposite direction
Nov 14, 2007 | SanDisk Sansa e140 MP3 Player
Don't know how to delete files
1. Open the file browser on your computer and navigate through the folders to the drive assigned to your Sansa MP3 Player. 2. Select the music files that you would like to delete by clicking once on the file, if you want to delete more than one file hold your control(ctrl) key down as you click each file. When you have clicked on all the files you want deleted release holding down the control key. Then push the delete key. The files will be deleted. You also can use Rhapsody and other software to save or delete files directly to your player.
Jul 14, 2007 | SanDisk Sansa e140 MP3 Player
Not detecting sansae140
Pls call the customer service Ph# 800-426-6027 they will help u out with it
May 30, 2007 | SanDisk Sansa e140 MP3 Player
Sansa e130 cant open
On not being able to detect any files when viewing Sansa in windows: try changing the format mode on the Sansa device - on mine I go to Settings and then USB and then changed it to MSC. I was then able to see the files in Windows and delete a bunch of them and then resynch in Windows Media Player.
Dec 20, 2006 | SanDisk Sansa m230 MP3 Player
No enough memory
It simply is saying you put to many songs on the mp3 player and you need to delete some by connecting it to the computer and delete them, one way to stop this it to upgrade and get a bigger memory stick.
Oct 24, 2006 | SanDisk Sansa e100 MP3 Player
SanDisk Sansa e140 MP3 Player Logo
415 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
