My Windows XP system was corrupt, how could i repair it?
  • 436 Answers
Try doing a restore or you may need to use the install disc to repair it.
Posted on Mar 26, 2011
  • 368 Answers
Glad to HELP YOU!
To fix your Windows XP you will need the installation disk.
Start Windows, let it boot and run and when every driver is loaded and when you will not notice any hard drive activity (the LED will not blink) you can insert your Windows XP installation disk.
On the screen that will appear (a blue color with many options) you will choose WINDOWS REPAIR.
That way your system will "update" all drivers it needs for a perfect functionality.
When it will be done click on EXIT option on the same blue window as before.
My best regards!
    Guru:
  • 433 Answers
In control panal chose system restor and follow stepes
How to Restore XP Backup Data in Windows 8 OS?
Microsoft offers file transfer support.
Apr 25, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Tip
REPAIR WINDOWS XP CORRUPTED OR MISSING (NTLDR) FILE/S To repair missing or...
REPAIR WINDOWS XP
To repair missing or corrupted system file/s, boot up with the Windows installation CD then –
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
on Apr 04, 2010 | Computers & Internet
Have corrupted files on my acer travelmate 2300
So are you running xp or windows 7, either way you could put in your operating system discs and go through the prompts and repair computer, windows 7 will find error and correct as will xp, but with xp if you choose repair you will lose all updates and servicepacks, or you could try these instructions on the link below
http://support.microsoft.com/kb/307545
Cheers
Sep 24, 2012 | Acer TravelMate 2300 Notebook
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
Two problems: how do I replace corrupted windows xp system files without using reimage repair. I do not not have the install disks. and, I want to edit text on a document. what free software can...
Yes you can replace corrupt Windows XP system files on your PC without re-imaging, Just insert your Windows XP disk in the PC the Windows XP CD will give you a splash screen that will give you a repair option. Click on it an Windows repair will start that will replace/repair all your corrupt problems.
You have not mentioned which type of the document you need to edit however if you have the most common MS Word .doc file than it can be opened in "WordPad" which ships free with Windows. To access it go to and click the Start button and then in the stop menu select Accessories. You will find WordPad there.
Good Luck!
Jan 09, 2011 | Computers & Internet
Windows could not start, file is missing or corrupt-windows, system 32, config system. to repair file using original setup CD-ROM, select "r" at first screen to start repair. What is this?
Hi !
If you enter in Windows XP set up, below instructions will appear:
1. To set up Windows XP not, press ENTER.
2. To repair Windows XP installation using windows console, press R.
3. To quit set up with installing Windows XP, press F3.
By pressing ENTER means it will repair your operating system and it will delete all your files in hard disk drive leaving nothing to that particular drive or partition.
By pressing R means it will repair your operating system files only and it will not remove your files.
By pressing F3, it will exit the Windows XP set up.
I hope this is helpful and thank you for using FixYa !
Jan 06, 2011 | Computers & Internet
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
My lap top will not turn on giving error message windowssystem32congfigsystem
Copy \windows\repair\system
Copy \windows\repair\software
And Thanks.
Mar 18, 2010 | Computers & Internet
Need to reboot my crashed computer cant get windows xp to reboot
HI how are u, ur Windows Xp is corrupted
Cause :
1. Viruses
2. Computer was not Shutdown properly
3. Some windows File Corrupted
Solution>>>>>>>1.
1. Go to Safe Mode at starting mode press F8.
2. If Computer Go to safe mode successfully>>
3. Go to start >> Programs>> Accessories>>System tools>>System restore.
4. Restore ur computer in privious date.
Solution>>>>>>>2.
1. Insert WIn xp cd in cd rom and restart it.
2. Repair Your win Xp via a Repairing utility.
Solution>>>>>>3
1. VIa a formmating utility U can install a new fresh copy of windowxs.
Thanxs
Mukesh Kumar
Mukesh_ibm@yahoo.com
May 12, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
