Question about Pioneer AVH-P5700DVD Car DVD Player
WHAT COLOR IS THE BRAKE WIRE TO ALLOW MY DVD TO SHOW ON SCREEN
  • 902 Answers
Its usually the red/orange wire on most dvd players that connect to the parking brake
Posted on Mar 26, 2011
How do i bypass parking brake wire? do i connect to negative or
what color is the wire from the radio it might be pink or purple with white strip. but the wire needs to see ground or parking brake wire
Mar 07, 2010 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Dvd won't play, reads parking off on the screen
you have to hookup parking brake wire up to ground. this will allow the dvd to show
Sep 25, 2009 | Kenwood Excelon KVT-915DVD Car DVD Player
Ddx512 Kenwood Parking off problem
Indash DVD units are programmed not to allow DVD's to play while the car is in motion. The unit only allows DVD viewing when the car is parked and the parking brake activated.
To get around this, you simply splice the parking break wire from the radio to the -NEG wire of the radio.
If this doesnt help let me know.
Mar 31, 2009 | Kenwood DDX-512 Car DVD Player
I have a dual brand car monitor stereo that won''t show dvd
hi there
well to start the e-brake will need to be applied to allow you to see the video if it was installed correctly.................to over ride this feature you need a toggle switch with 3 pins on it
on the toggle switch there should be two logos (power & ground) if you run a small wire from the red wire from the back of your in-dash system to the toggle switch (power) and do the same for the black wire (ground wire)..........the last pin on toggle switch you attach the e-brake wire from the back of your in-dash system to the toggle switch pin and turn it on video will play
if this doesn't work switch the e-brake and ground wire around on the toggle switch
hope this helped
Nov 28, 2008 | Car Audio & Video
Jensen vm 9312 parking brake bypass
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Sep 17, 2008 | Car Audio & Video
Help me find parking brake wirew what color
Don't bother - just ground the wire that ties into the brake. This will allow you to watch while you drive. You may need to put a switch on the wire (so you can break the connection if need be - Jensen for one requires an on-off-on sequence with the brake, and you can duplicate this with the switch). Overall it's easier that tapping into the brake wire and gives you more flexibility with the system as well.
Aug 22, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Bypass the parking brake on the vm9022
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 16, 2008 | Jensen VM9510 Car DVD Player
Kenwood kvt-719 brake bypass code needed
I've never seen a code that allows it, but you can do it in the wiring harness. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 15, 2008 | Phase Linear UDV9010 Car DVD Player
Iva-d300
Jul 10, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Cant get unit show dvd's
sounds like dual zone is activated, itll allow you to play dvd in back but not when youre driving. you may have to frig the unit to allow dvd display whilst driving, this usually involves a cable thats supposed to connect to your handbrake.
copy and paste link into your browser toget manual:
http://service.us.panasonic.com/operman/findmanual.aspx?model=CQVD7003U
Mar 22, 2008 | Panasonic CQ-VD7001U Car DVD Player
Pioneer AVH-P5700DVD Car DVD Player Logo
108 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
