Question about Husqvarna Garden
One question, im looking to buy a husqvarna k760 demo saw, i need to cut metal, such as truck and trailer frames. just need to cut them down to length so i can load and bring to scrap yard. i figure it will pay for itself in a couple loads. just wondering if this tool will be able to handle this work. also what are the black blades for cutting metal called, so i can order some. thanks for the expertise, Tony
  • 710 Answers
The K760 black cutter blade is called a Cut-n-Break blade. The manufacturer states that it has an improved stable core to increase its performance. I have a friend who recycles scrap metal and uses the Mastercraft 5" dual cutter. It cuts through metal like butter without any kickback.
Hope this helps,
Handie Andie
Posted on Mar 26, 2011
Husqvarna wont idle k760 what do I need to do
Replace the air filters.
All cutoff saws plug air filters to the point they cannot breath. Do not replace just one, replace them ALL !
You might also need to replace the spark plug.
Feb 02, 2017 | Husqvarna Garden
Saw starts, but why does it run few seconds then quit?
Has it enough compression ? because i have the experience it have a questionable closing system for carburetor air filter it is not always fully locked take care to close it replace parts if its not as soon as this problem is there or its to late , on the way it should but when it is not good closed it leaks in much cases and the piston had often grooves by polution from graveldust it can have lost compression by it first to do is control the piston.
In the event that all of this is not the subject the tank airiation and fuelhoses to control.
51MM Cylinder Piston Kit For HUSQVARNA PARTNER K750 K760 REP 506 38 61 71
Feb 11, 2016 | Husqvarna K760 Cut-off Saw,2-cycle...
Why is throttle stuck wide open?
Could be a couple of things. could be a return spring sticking on the carb, or the throttle cable has frayed and sticking on. I've added the breakdown manual for you.
http://www.mediafire.com/download/68zm589mejh8jnq
Dec 20, 2015 | Husqvarna-Target Husqvarna K760 14 Inch...
How to replacethe primer bulb
look only the brand and numbers of the used carburetor WALBRO most of the times or ZAMA the model
FIND PARTS FAST look there
Sep 11, 2015 | Husqvarna K760 Cut-off Saw,2-cycle...
Saw runs at normal idle with choke pulled and wide open with choke off
I would take it back to the repair person you used and let them know that they fixed one problem and caused another.
Jul 09, 2014 | Husqvarna 12"" K760 Concrete Saw"
Will this saw be able to cut steel on truck and trailer frames? the steel may be 2-3 inches thick in some places. other places only about a half inch thick. is this a good tool for cutting heavy metal?
Never heard of cutting steel with a chain saw. What works best for me has been a sawzall with a good quality steel cutting blade. The real thin metal cutting blade on a circular saw works pretty good also.
Mar 28, 2011 | Husqvarna Garden
Garden Logo
183 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
