Question about Microsoft Xbox 360 Console
HOW CAN I GET MY XBOX 360 DVD DRIVE HITACHI TO WORK WITH OUT REPLACING THE DRIVE AND HAVING TO WAIT FOR IT TO GET REPAIRED...ITS A RECESSION
    President:
  • Microsoft Master
  • 1,623 Answers
Replace the laser , if that is what the problem is, they are not that expensive.
heres a vid to watch how to do it
http://www.youtube.com/watch?v=BMissjiWwh8
and you can buy a laser from here if your in the us for very cheap
http://www.amazon.com/Laser-Lens-360-HITACHI-Drive-GDR-3120L/dp/B004H83PEO
Posted on Mar 26, 2011
Xbox 360 DVD Drive Not Reading Games Only DVD,CD after replacing the dvd rom
If you replaced the DVD-ROM drive yourself, some newer Xboxes do not recognize and/or function properly with older drives. I tried replacing a drive in an older Xbox with an older yet DVD-ROM drive, and it would not work. When replacing a DVD-ROM in an Xbox, it is advisable to use the same model drive, as the Xbox does strange things when you introduce different hardware. The url of a page is below that details the different drives that Xboxes use. See if your new drive is the same as the old one, and if not, that is almost certainly the issue.
http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
Good Luck!
Jul 07, 2011 | Microsoft Xbox 360 Console
Tip
Xbox 360 - Stuck or sticking tray fix!
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on May 13, 2010 | Video Game Consoles & Games
Tip
If your Xbox 360 Disc tray won't eject
SAMSUNG:
on Feb 02, 2010 | Video Game Consoles & Games
DVD Rom replaced
When you switch the original dvd rom to a replacement. you MUST remove the logic board from the original drive and put it into the replacement drive for it to function
Apr 19, 2009 | Microsoft Xbox 360 Pro System Console
My xbox 360 keep sayin play dvd
the x clamp fix is for heat issues...this is a dvd drive issue...you may need to replace your dvd drive...but you cant just swap them out...you have to transfer your original PCB board from your broken drive to the new drive or it WILL NOT WORK....the dvd drive and motherboard are paired by a key...the keys for both have to be the same...you need to find out which drive you have...the BenQ is a pain unless you know how to flash the drive to get the key and transfer it to the new one...otherwise it means a soldering iron and some tiny little wires and some patience...there are tutorials and changing dvd drives...just google it
Mar 30, 2009 | Microsoft Xbox 360 Console
Xbox 360
bad dvd drive
Bad Cdrom/dvd
The laser going bad is a pretty common issue with the drives, since it's a Hitachi that spindle motor could be all gunked up with dirt as well and cause that issue also.
if ya have a Hitachi, if it's a Samsung it could just be the laser.
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Dec 19, 2007 | Microsoft Xbox 360 Console
XBOX 360 will not read game disks
Bad Cdrom/dvd
Dec 18, 2007 | Microsoft Xbox 360 Console
Xbox 360 reading error
Bad Cdrom/dvd
Dec 17, 2007 | Microsoft Xbox 360 Console
How do I re-flash dvd drive for xbox 360
did you just buy a dvd drive or os it an xbox360 dvd drive?
I think this might be what your looking for.
http://www.llamma.com/xbox360/repair/hitachi-disassembly.htm
Dec 11, 2007 | Microsoft Xbox 360 Console
How to re-flash dvd drive for xbox 360
read this first:
Nov 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
