I have a panasonic tv model PT-50LC13 am i able to connect a blu ray to this tv?
  • 902 Answers
Yes you can via component cables or rca *red yellow white* or svideo i cant recall all the inputs your tv has . if it has hdmi hdmi is the best way!
Posted on Mar 26, 2011
HDMI slot is absent in this tv. How can I adapt it to handle HDMI?
Yes, the Panasonic PT-50LC13 has a DVI port. There are DVI to HDMI adapters to handle the conversion. You will need an HDMI F to DVI-D M adapter (like this: http://www.amazon.com/Importer520-Plated-Female-DVI-D-Adaptor/dp/B0035B4LJM/ref=pd_sim_e_1 ). Alternatively, get an HDMI to DVI-D video cable (both male ends) of the appropriate length. You will need a separate cable for the audio. Make sure that your source has a separate analog audio output available and plug that into the DVI audio input (RCA R/L). If your source has a only digital audio output and the HDMI port, you could use a digital-to-analog audio converter to provide this audio. For example, this would work: http://www.gefen.com/kvm/gtv-digaud-2-aaud.jsp?prod_id=5279 .
Please note this will not handle the signal from most computers. They send a different signal then the TV can handle. Copy protected content (DRM) may not be correctly translated by the TV. Most Blu-ray movies require HDCP compliant TVs and monitors.
I hope this helps.
May 27, 2013 | Panasonic PT-50LC13 50" Rear Projection...
Where is the lamp reset button on my panasonic PT-50LC13
To reset the lamp on the Tv you need to Hold down vol - on tv and hit either PIP or SPLIT on remote Good Luck
Nov 12, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 reset lamp timer
Replaced the Lamp, on my PT-50LC13 pan TV. But cannot reset the timer because the screen does not light up. and the instructions say to hold down the -Vol button and the pip button. But which one? there are 3 buttons with the word PIP
Apr 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Have panasonic pt -50lc13 tv
Jan 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
