Question about Garmin GPS
How to take a garmin nuvi 680 off usb mass storage mode
  • 902 Answers
When you go to tools/settings there is an option for the sd card and you may take it off usb mass storage mode. or simply take out the card and put it back in.
Posted on Mar 26, 2011
Mass storage mode usb
Common problem with this model is a loose USB port. More info on USB port issues can be found here:
http://www.sharc.net/gps_charger_repair.htm
Nov 11, 2013 | Garmin nuvi 1350 Car GPS Receiver
Reboot the Nuvi 360 to "Mass Storage Mode"
1. Connect Nuvi3xx to PC vis USB Cable for 7xx to go into
mass storage mode.
2. Slide Power Switch to the right (LOCK Position)
3. Click the "Safely Remove Hardware" icon in system
Tray on PC (Lower Right)
4. Click on "Safely remove USB Mass Storage Device -
Drives(x:and y:)" x: = mass storage for the 3xx and y: = the
SD card if one is installed
5. WAIT for 3xx to Boot UP.
6. After 360 Boots UP slide power switch to center
position
Sep 30, 2008 | Garmin n vi 360 GPS Receiver
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Garmin shows picture of computer
When the Garmin shows the picture of a computer, it means that the Nuvi is in mass storage mode. This mode is used to load software and map updates to the Nuvi and will usually go into this mode when connected to a computer or improper USB cable.
If this is occurring when it is connected to the vehicle power cable, chances are that the vehicle power cable is the wrong one.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 23, 2012 | Garmin nuvi 1450 GPS Receiver
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
My nuvi 200 is in mass storage mode. How do i
Connect to a computer with your usb cable. Use the safe disconnetion function on you computer (one of the small icons on the down right side of the screen toolbar).
Jun 11, 2010 | Garmin nuvi 200 Car GPS Receiver
My laptop won't show my Nuvi 680 as a mass storage device
I have a couple of ideas based on the information you gave:
1. That Nuvi has an SD card slot.  If your PC has a memory card reader, you could insert an SD card into the machine, copy whatever you want onto that, and then pop the card into the Nuvi.
2.  While the Nuvi is hooked up to the PC goto the hardware device manager (In XP right click -> My Computer -> Properties -> Hardware tab -> Device manager) and see if anything has an ! or a ? next to it.  If so, that's probably related to your Nuvi and resolving that usually involves reinstalling the driver or updating to the latest driver.
More detailed info on what you're trying to do and the result of the above could get a more specific fix.
Nov 19, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
439 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
