Officejet J4680 won't printer after router reset
) You might not have to do this step, but if all else fails reset the HP
Officejet J4680 network by pressing the setup button (the wrench) go
to Wireless Menu and Press OK then go to Reset Wireless select YES and
press OK. If that doesn't work then there is another reset that I found
in the setup menu (the wrench) under Tools and then Restore Defaults. I
wound up doing both resets on my Officejet J4680
2) Power the HP Officejet off and on for good luck (again optional but might help).
3) Make sure the the wireless on the printer is enabled by pushing the
button on the left side front under the 802.11g so that the blue
wireless light turns on. (again optional, but make sure the blue
antennae light is on)
4) Connect to the HP Officejet J4680 wireless printer directly from the
MAC (this is pretty cool stuff) Click on the Airport icon at the top bar
of your mac screen, if you see the hpsetup listed then click on it, if
it is not listed then click on join other network and type in hpsetup
and click Join. This will join the mac to the Ad Hoc HPSetup network
and you can now setup the printer from the mac!
5) Important: Print a network
settings report on the HP Officejet by pressing the setup button again
(the wrench) go to Print Report and press OK, go to Network config and
press OK. If you try and print this
before you connect (step 4) you will not get the info you need in the
report, so connect first from Mac to HP then print this report.
6) fire up safari or Firefox or chrome browser on the Mac and type in
the URL that is listed on the report you just printed out. It starts
with http:// type in the http:// and the 4 numbers all together with no
spaces into the address bar in your browser and press return.
7) you are now connected to the HP Officejet J4680 via the web browser
interface. Click on Networking, then Advanced, click the infrastructure
tab and fill in the passphrase info for your router type it again to
confirm, then click apply. It should now connect and print from the
router. But below is a good video with even more detailed info:
8) More Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
