Not an ACPI. need bios update - Computers & Internet
    Guru:
  • 433 Answers
Name of mother board is writen besid the the ram bank take and write in internet search and follow wih you success
Posted on Mar 26, 2011
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
RESOLUTION
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
I have ACPI problem. said when i was trying to install os on my system and it said "the bios in this system is not fully ACPI compliant" pls what can i do
For that particular software you are using,,the ACPI thinks your Bios needs updating.
You can re flash the Bios to a newer version if one is available, and if one isn't available,,then i would suggest turning off the ACPI functions in your system Bios.
ACPI controls the power saving features of your machine via the software, also the power saving features on any legacy devices attached to your system.
Jan 19, 2009 | Computers & Internet
The BIOS in the system is not fully ACPI compliant. I want to updated BIOS. How can I do?
Hi meangmoeurn, what makes you think your bios is not ACPI complaint?
Enter your bios & disable ACPI. The reason for this is windows must be fully updated. One windows has been fully updated you can turn on ACPI. Its a software issue.
Read through this Microsoft link;
http://support.microsoft.com/kb/314088
Update for ACPI, (Windows update);
http://www.microsoft.com/downloads/details.aspx?familyid=B0FF829D-C427-4F40-BC56-F481837EFFBE&displaylang=en
The above update should be included with other updates. This is why I suggested the above.
If you still feel you need to update your bios,
(Flash Utility software). I'll need the motherboard model number & manufacture's name.
Good luck meangmoeurn!
Feel free to correct me on this issue.
Thank you for using fixya.
Mike
Jan 11, 2009 | Computers & Internet
Acpi bios
Hi suleman_indi, I'm guessing you have a question about the D845GVSR motherboard. If your question refers to the bios setting for ACPI. Disable it until windows has been updated to SP2. Enter your bios & enable the ACPI. Should be fine once windows has been updated. Click on this link to load Intel's site for the Intel D845GVSR motherboard.
http://downloadcenter.intel.com/Product_Search.aspx?Prod_nm=+D845GVSR&lang=eng&MissingSearchTxt=Please+enter+a+valid+product+name%2C+filename+or+product+ID+%23.&x=21&y=5
If you find you need more information, feel free to update your question.
Mike
Sep 09, 2008 | Intel D845GVSR Motherboard
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE
http://www.medionusa.com/ and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also http://www.treiber.de/ may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Dec 04, 2007 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
