Question about Polar RS400 Heart Rate Running Computer Wrist Watch
Stop button is not working - Polar RS400 Heart Rate Running Computer Wrist Watch
    Guru:
  • 347 Answers
You will need to send into a Polar Authorized Service Center. If it is under a year old, probably still under warranty.
Posted on Mar 26, 2011
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
My armitron all sport watch works, it's only 1 month old, buttons stopped working. any ideas
try to put a new battery..whether it's only 1 mo old ypu can't tell the watch you bougth has a new battery inside.
Feb 02, 2013 | Armitron Watches
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
Aug 04, 2011 | Tissot PR50 Sport Chronograph # T34152852...
I have an athletic works stopwatch. All it says on the front is chronograph. I bought it at Walmart. It has 3 buttons on the top and one on the bottom. I can't find the directions. I can't get it to...
I have the same Athletic Works stopwatch. I just figured out how to turn off the alarm: press either of the two mode buttons (middle top, or bottom right) until you see the regular time displayed (the seconds will be changing, but nothing else, and nothing will be flashing). Press and hold the reset button (top left); while holding down the reset button, press the start/stop button (top right). Watch the bell icon on the display in the upper right corner; with each press of the start/stop button you will see the bell either appear or disappear. When the bell disappears, release the reset button. The alarm is now off.
Apr 14, 2010 | Watches
INDIGLO does not work anymore
Take this to a qualified watchmaker for inspection.
If you have any further questions please let me know.
Many thanks!
Mike Kenley
TimeOut
Worldwide watch and clock services
If it don't tick I can fix
Nov 29, 2009 | Timex 27191 Wristwatch
I cant get stopwatch to work
Stop watch button is malfunctioning it is already stuck up,put a little oil on the stop watch button or "WD 40" or desame kind.Try that so it will works normal again.
Hopes it may help you;
Regards,
VOTIT
Oct 06, 2008 | Fossil Watches
How do I work the lap timing function work?
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
Sep 03, 2008 | Timex 1440 53591 Sports Quotient...
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Mar 30, 2008 | Timex 1440 Nylon watch
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Polar RS400 Heart Rate Running Computer Wrist Watch Logo
117 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
