Question about Car Audio & Video
I recently sold my car and someone else removed my stereo and I have since discovered that they only removed the head unit itself and left the cables in the old car. Does anyone know where I could get replacements and if they are model specific?
  • 902 Answers
You can get teh cables at walmart and new head units there as well as adapters specific for your model so you dont need to attach cable by cable. please let me know if that answered your question as it was a little hard to follow
Posted on Mar 26, 2011
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
How do you remove radio, from my 2001 dodge neon, that just went dead, for no reason. I replaced the fuse on the side of dash board. Still nothing.
Safety Precautions
  • Before removing the stereo or any other electrical component, it is vital that you first disconnect the grounding cable from the Neon's battery. The grounding cable connects the battery to the frame or chassis of the vehicle.
    Use a Phillips-head screwdriver to loosen the grounding cable's camp from the negative battery lead. Make sure to rest the clamp away from the negative lead post until the removal is complete.
  • Remove the Dash Trim Panel
  • The dash trim panel that surrounds the Neon stereo needs to be removed to access the stereo. The panel contains, but is not connected to, the climate control knobs on the dashboard.
    Grab the panel at the bottom corners and pry it from the dash. You will likely be able to remove the panel without the assistance of a trim pry tool, but if you are having difficulty removing the panel by hand, wrap a thin cloth around a trim panel removal tool or flat head screwdriver to remove the panel.
    Once the lower edge of the panel is relieved from the panel, you can work your hands (or flat pry tool) around the perimeter to separate the remaining edges.
    Since the panel is not connected to the climate control knobs, you will not need to disconnect the wiring to the knobs. The panel, once free, can be set aside until you replace the stereo.
  • Remove the Stereo
  • The Neon stereo deck is held into the stereo mounting bracket by 10 millimeter bolts on either side of the radio. Remove the bolts and store them in the ashtray for safe-keeping.
    Pull the stereo from the dock. The unit will easily slide from the mounting bracket with an even pull from the left and right of the stereo. Pull the stereo far enough to reach the wiring on the rear of the radio.
    The wiring to the stereo includes the antenna, the power supply and the speaker wires. There may also be patch cables connected if an amplifier is connected to your stereo system. Pull the cables from the stereo. The antenna and power supply are single cables. The speaker wires (and patch cables) will be grouped by wire binders. The plastic wire binders should be pulled as a unit. Do not pull the wires themselves.
    Once the wiring has been disconnected from the stereo, the unit will be completely free from the Neon.
    If you plan to operate the vehicle before installing a new stereo or re-installing the factory deck; reconnect the grounding cable to the negative battery lead. Otherwise, leave the cable away from the negative lead until all of your work is completed.
  • Feb 26, 2011 | 2001 Dodge Neon
    How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
    Well you can please follow the below steps -
    1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
    2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
    3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
    4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
    5. Connect all of the ignition power wires to your Pioneer stereo.
    6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
    7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
    8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
    Good Luck!!
    Thanks
    Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
    Screen/radio/check gauges/dash HELP!
    Ok there oil presure plug that gets dirty next to the oil filter you can replace if oil presure ore just spray with some car spray see if that works.
    With stereo pull out buy cheep one see if does the same with the cheep unit could be head unit.
    Jul 21, 2009 | 1996 Jeep Grand Cherokee
    My bose car stereo system no longer has sound. When the radio was first turned on, it would take approximately 5 minutes until there was sound coming from the speakers. This got progressively worse until...
    i had multiple problems with my stereo in my terrano just recently. first started with the digital trip meter going out and no audio, that was to do with the earth cable which came from te car. on mine it was a pink and silver cable, maybe it was done wrong from who ever wired it in first but it didnt like it so i went straight from the head unit to the chassis... secondly it could be the amp control cable. it may be loose or something. and thirdly a problem my friend encountered with his stereo was that the unit would turn on but no audio and after sctatching at our heads for a while we thought we'd go through from behind the head unit and remove each speaker when we took one out of the equation we got audio and it was because the speaker was shorting against the car body which would prevent any other speaker from working. hope these help. as for the dimming im not quite to sure maybe get a multi metre onto the power and see if its reading 12v.
    Mar 19, 2009 | 1999 Nissan Pathfinder
    JVC car stereo doesn't power up
    Check the ground wire. It might have come loose. Ground wire is the only black wire in the harness.
    Mar 12, 2009 | JVC Car Audio & Video
    Right rear speaker not working
    Start by connecting it to one of the other outputs off the deck, say the left rear. If it still doesn't work, remove the speaker and connect it directly to the head unit. If it works, then it's the speaker wire, if it doesn't, it's the speaker.
    If there are amplifiers installed, switch RCA cables left for right etc. and see if the problem moves with the cable switch, try the same with the speaker connections at the amp. This will narrow down whether it's the amp or the RCA cable etc.
    Car audio problems can be handled by a process of elimination! Eliminate what it's not and you're pointed directly to what it is.
    Oct 06, 2008 | Pioneer DEH-P7700MP CD Player
    Amp buzzing in range rover
    Have you had any electrical work done to it recently?
    ... try two things.
    One, unplug the RCA cables from the amps to see if it is with the signal or with the amp itself.
    Two, check the ground connections for them to be nice and clean as this may cause this issue.
    If the buzz stops when unpluggin the RCA cables.. it's either a problem with the cables or with the Head unit sending this weird signal. (NOTE, if ALL speakers have the buzz it's mostly caused by the HU, thus, if it is only with one side as you explained, I'll lean towards a bad cable, or an amp failure (either not receiving proper ground, or it has gone bad.).
    Hope this helps you some. if not, lemme know and I'll try to help you thoroughly.
    Fred
    Feb 18, 2008 | Car Audio & Video
    Car Audio & Video Logo
    23 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
