Question about Seiko Watches
Seiko watch 100M 665850 water resistant 10Bar ST.Steel
Richie_asg1
  • 1036 Answers
SOURCE: Need an instruction manual for my Casio Triple Sensor watch
Hi there!
This site is quite useful - http://www.theusermanualsite.com/
Just log in with your Email & postcode to get a PDF of the information it holds.
If this assists you, Please rate as Fixya! (It's free)
Posted on Jun 21, 2008
escapement
  • 2334 Answers
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 04, 2009
  • 110 Answers
SOURCE: How do you remove a back off a old seiko watch
If you see the indentations on the case back to accomodate a tool, then you need that tool and unscrew counter clockwise. If you don't see those indentations then the case back then you should be able to pry by using the proper tool. You might be able to use a small bladed tool, like a knife, but be very careful that you dont slip and cut yourself. Go between the case and one of the band posts to get leverage.
Posted on Nov 10, 2009
  • 8 Answers
SOURCE: I need an owners manual for a Seiko 100M watch...
go to this address http://caliber.seikowatches.com/
select the desired language and play the instructions on your right one by one
Posted on May 19, 2010
escapement
  • 2334 Answers
SOURCE: How do set alarm on my Seiko stainless steel water
Click on my name (escapement), then click on TIPS AND TRICKS. Browse through all and you will find the link to all SEIKO watch manuals. Rate me, please.
Posted on Jun 24, 2010
Seiko5 watch service centre in abu dhabi
Take it to a local jewelry shop and have them either fix or send it in for repairs
Aug 10, 2016 | Seiko Wrist 5 SNK665K1 Automatic...
How do set alarm on my Seiko stainless steel water resistant 10 bar alarm watch?
Jun 24, 2010 | Seiko Sportura SNJ007 Wrist Watch
May 17, 2010 | Watches
Looking for user guide for model 4511 Desert Falcon Zodiac watch
Clearly a screwdown crown is better for water resistance but most watches maintain a seal without it. I wouldn't test out the 100m claim but it should be safe in the pool.
Apr 29, 2010 | Watches
I have a Ricoh watch that has " ATRANTA Water Resistant 10BAR" on the face. Face is red in colour, has day and date scroll. Day of week can be seen in English or (guessing)Chinese or Japenese script. Back...
Ricoh Elemx AT Corp. is subsidiary company of Ricoh Elemex Corp.
The Hamilton Ricoh Watch Company, Ltd. was a joint venture (60% owned by Hamilton) and only existed between 1962 and 1964. Electric parts were made in Lancaster, PA while the mechanicals parts were made in Japan, the watches also being assembled in Japan. The movements are marked "Ricoh 555E", but are the same as the Standard Time Corp. 130E (fitted in Hamilton's Vantage range), which in turn is very similar to the Hamilton 505.
Although the factory was turning out 1000 / month, very few were sold. Marketing was handled by Ricoh but they failed to break the stranglehold and monopoly that Seiko had in the Japanese stores; in the end, most were sold on US military bases in Japan.
The partnership was dissolved in 1965; some of the Hamilton Ricoh movements were re-cased as Vantage and sold in the US.
Now Ricoh is owned by Elemex and they still producing watches. Follow this link and see for yourself:
http://www.ricohelemex.co.jp/en/products/req/
Unfortunately, I cant give you any details about your watch, except that the 10BAR means your watch can withstand 10BAR pressure, and that is 10 meters under water.
The bar (symbol bar) is a unit of pressure equal to 100 kilopascals, and roughly equal to the atmospheric pressure on Earth at sea level.
Rate me, please.
Feb 28, 2010 | Watches
How do you remove a back off a old seiko watch, it's water resistant st. steel back. there is some number's on the back, 5y23-8039
Nov 10, 2009 | Watches
Perpetual Calendar 100M, Ineed the instruction
Follow this link and click on OPERATIONAL GUIDE.
http://www.seikousa.com/#FAQ
Rate, please.
Jul 29, 2009 | Seiko Coutura Perpetual Calendar Watch
Job done!
Apr 04, 2009 | Seiko Watches
Hi there!
Jun 21, 2008 | Watches
Watches Logo
109 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
