We have a big screen tv, it has a plexi-glass like covering, it was scratched not really deep but long, is it possible to repair this or would it have to be replaced?
    Champion:
  • 217 Answers
Has to be replaced
Posted on Aug 03, 2008
PC Moniter with scratch
You can't get the scratch out, since it's embedded there by metal. you can patch it up with clear tape or use glare reduction monitor screen.
Mar 06, 2010 | Computers & Internet
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
I have a 3 inch scratch on my plasma tv that happened in a move. I think it is a glass screen. Is there any way to cover or fill this scratch. It isn't very deep but it bugs me that I can see it.
You must determine whether or not the scratch is on a protective fromt screen or the panel itself. I don't know your specific model, but some of the LGs have a front glass behind which is the actual panel. If that is the case with yours, you can replace the front glass. If it is only the panel, then there is no way to repair other than replacing the panel which is VERY expensive.
If you wish to try something, go to a local auto parts store and purchase a windshield repair kit. This will contain an optically transparent epoxy that can fill in the scratch and make it at least less noticable similar to filling a scratch or crack on a windshield.
Dan
Mar 06, 2009 | LG 30FZ4D TV
I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My plasma tv has several really deep scratches on the screen, how can i go about repairing this?
There are liquid solutions for filling LCD scratches
it's basically a plastic material that fills the scratch.
Big scratches are more of a problem. I am assuming that your
Plasma screen has a glass surface and that it's only scratched,
not physically broken. You may also try glass polishing compounds
for filling and polishing chipped windshields. Be careful, try it on a small spot first to make sure that you don't dissolve any plastic anti-reflection coatings etc.
Good luck
Apr 18, 2008 | Computers & Internet
How do I remove the outer protective screen on my Mitsubishi WS-55315?
There are trim pieces around the edges that can be removed by sliding a knife underneath and lightly prying. They should remove fairly easily, don't force them as they may break. Use the knife on the cabinet side and pry toward the center of the screen.
The tear on the inner screen may be best left as is.
lexan would be better than plexi as it is tougher, but try to get anti-glare if possible. Anti-glare plexi would be better than regular lexan.
Feb 17, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Scratches on the screen
if the screen prot. is damaged,replace with plexi glass..avail thru local home improvement suppliers...good luck...john
May 28, 2007 | Akai PT4298HD Rear Projection Television
How can I fix a light scratch on the plexi screen
There is a product for polishing platstic that removes minor scratches. I don't however remember the name of the product and if you do obatin it try it in the corner of the screen first to verify it won't do further damage to the screen.
Apr 23, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Electro Med Services...
