Yeah uninstall the webcam and the software then plug in the web cam and see if it finds the drivers automatically (win 7 n vista will) and skype will pick it up. if not just install the drivers NOT the software
you can do it that way. or search for drivers then point it to the disk with the drivers on it.
Tried both methods. running XP on a desk top. Installed drivers using "Add Hardware" Is that the correct method?
Search for drivers using which utility?
when you add new hardware there should be an option to specify the location you want to search. it will on your cd
there are no cameras shown in "Scanners and Cameras" in the control panel...only my scanner. When I try to add one it does not accept the INF files that are available. Since I'm running this on a machine with XP and the drivers appear to be for 95 and 98 perhaps a new driver would help but 3com does not make or support this camera any more. Maybe another driver would work from another camera. I'd heard that the Intel CS331 driver might work and I tried it but the Add Hardware utility won't take it. This whole thing is odd because the camera, with its original driver, works fine with the programs thatcame with it and with Net Meeting...but not with Skype. Any idea if there would be a driver that would work with Skype?
Tried both methods with no success. Running XP on a desk top.
Installed drivers through Add Hardware. Is that correct method?
there are no cameras shown in "Scanners and Cameras" in the control panel...only my canner. When I try to add one it does not accept the INF files that are available. Since I'm running this on a machine with XP and the drivers appear to be for 95 and 98 perhaps a new driver would help but 3com does not make or support this camera any more. Maybe another driver would work from another camera. I'd heard that the Intel CS331 driver might work but I'm reluctant to try it without some form of expert opinion.
nd this solution on a User Page at Skype. Download Manycam athttp://www.manycam.com/. Start Manycam, then start skype and use Tools, Options, Video Settings to select Manycam as your web camera. Worked for me.
