Question about GE Refrigerators
How do I clean the coils on a ge profile - GE Refrigerators
    Scholar:
  • 116 Answers
Hi, take the rear panel off in the back of the refrigerator and the coils should be on the right side, you can sweep out with vacuum or use brush. The screws are either 5/16 or 1/4" depending on the age.
Sean
Posted on Mar 26, 2011
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
MY GE PROFILE REFRIGERATOR DOES NOT COOL IT SHOWS 7 ON THE DISPLAY AND THE REFRIGERATOR SECTION DOES NOT FREEZ ANYTHING IT SHOWS 4 AS TEMPERATURES.
ck the fans and clean the coil underneath / dirty coil will cause poor cooling and fan that is not going or is going too slow .. mm
Sep 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
All of a sudden my GE Profile Artica's freezer is at 25 degrees and the fridge side is at 43 degrees. I've forgotten how to "set" the temperatures but I'm afraid that's not the problem. Any ideas?
I would clean the condenser coil. This coil is located under or in back of the frig. When they get dirty the frig can't pull down the temp.
It's a common problem.
I hope this helps.
Aug 23, 2010 | GE Profile Arctica 25.4 Cubic Feet...
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
