Question about Philips Televison & Video
Disc won't load on a phillips dvd player - Philips Televison & Video
  • 1153 Answers
SOURCE: Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Posted on Sep 05, 2007
  • 7 Answers
SOURCE: dvd player won't play disc
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
Posted on Jan 20, 2009
SOURCE: displays no disc
I had the exact same problem. When I finally opened the top there was another disk already in there. I guess if the unit shuts off and you leave aa disk in it will stay in the player even though when you open the door to place another disk in the tray will be empty. All you have to do is unscrew the cover aand then you will see a crossbar held in with two screws where the disks are. unscrew them and take out the two disks thay are stuck togeather. Replace eveything and rescrew and enjoy the movie!! Hope this helps!
Posted on Feb 08, 2009
SOURCE: Will not recognize a disc in the DVD player.
try formating it
Posted on Apr 11, 2009
konzzz
  • 255 Answers
SOURCE: dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
Posted on May 28, 2009
Protable phillips pet824 DVD player will play cd but not dvd's
follow this steps, and fix it. Merry Christmas.
However you must sure if you device can play any CD/DVD.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Dec 17, 2013 | Philips Televison & Video
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Wrong region DVD player won't play a disc
Can,t be done with the one you have,
Nov 10, 2012 | Philips Televison & Video
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
PET941D/37 won't load dvd says no disc
Some DVD players are proprietary. See if it will play in other devices. If it is a burned copy the player may not like that brand of DVD.
Apr 23, 2012 | Philips PET941D/37 9 in. Portable DVD...
Phillips dvd player disc draw won"t open help
Usually, there's a pin hole beneath the tray that come out. If there is a pin hole, get a paper clip or safety pin and insert the pin or clip into the pin hole and push. That should pop the disk tray out.
Mar 21, 2011 | Philips Electronics - Others
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
I have tried to load 5 different recordable discs in my trutech dvd record and the machine rejected all of them. What brand works in this machine??? [I tried Sony regular and re-recordable, Sony, Phillips,...
See if changing recording speed would help. As far as I know the discs should work. Try the discs that you have burned before on another player just to check if there is something wrong with the player.
Oct 05, 2009 | TruTech T650-DR DVD Recorder
Toshiba disc error
Jun 25, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
154 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
