Question about Harman Kardon DVD-22 DVD Player
Tray does not open - Harman Kardon DVD-22 DVD Player
    Top Expert:
  • Harman Kardon Master
  • 75,767 Answers
Hello
Its loading belt has broken. Loading and unloding are done by belt and motor drive. The belt between motor and loading gear wheel assembly have borken, that is why it doesn't opens. Replace the belt with same size. OK.
Posted on Mar 26, 2011
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Sep 04, 2014 | Toshiba Satellite Computers & Internet
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
My friend and I are haveing a prolbem with his xbox and it say open tray? can someone please help me?
open tray, unplug power cord while tray is open, plug power cord in, let tray close, open tray again, put disk in, close tray and tap on top of the drive while it loading.
Apr 12, 2010 | Microsoft Xbox 360 Console
Open tray comes up when loading a game?
Try tapping above the disk drive or if that doesn't work open the tray take your disc out close the tray. open the tray put ur disk back in and close the tray again.
Mar 15, 2010 | Microsoft Xbox 360 Elite Console - Black
Open tray
Hi, this is caused because your laser is either dirty or starting to fail. Take your 360 and turn it on, then open the tray. As soon as the tray is open, unplug your 360. Now with the tray open use a can of compressed air or an air compressor and blow out the DVD drive .And see if it is because your laser is dirty. Take your 360 and plug it back in and try putting a disc in it. If it still gives you the "open tray" error, then your laser is not reading the disc and needs to be replaced.
Aug 21, 2009 | Microsoft Xbox 360 Console
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Blinking green light on 1 tray
You could have a faulty drive.
To open the tray, you need a paper clip, straighten it and place it in the small hole below the disc tray, push it in and the tray wull pop out slightly, remove paper clip and pull the tray fully out with your fingers.
Then try to close and open the tray with the push button, if it does not work you need to replace this drive with a new one.
Sep 24, 2008 | Acard Technology (CD1TO7T) CD-RW Burner
DVD tray won't open
Look for a small pin hole in the front of the DVD player. Insert a pin into the hole to open the tray.
Also try right clicking the DVD icon, click 'eject', then insert the pin into the hole.
If the door only opens partially, grab it and pull it open. Then insert a blank DVD into the tray, then see if the tray will open automatically with the disk in the tray. If so, then keep a DVD in the tray at all times.
May 27, 2008 | Televison & Video
Disc tray
My console does the same thing just take the faceplate off and when you press the open button grab the disc tray and gently assist your console in pushing out the tray. Taking the faceplate off does not terminate your warranty.
Jan 12, 2008 | Microsoft Xbox 360 Console
Harman Kardon DVD-22 DVD Player Logo
362 people viewed this question
Top Harman Kardon Televison & Video Experts
Demonic-2011
Demonic-2011
Brett Duxbury
Brett Duxbury
Are you a Harman Kardon Televison and Video Expert? Answer questions, earn points and help others
