Question about Coleman Powermate Powermate 5000W Generator
I need a fule shut off valve that is pressed into the plastic gas tank, or a retrofit.
4 Suggested Answers
sal_kh_sab
  • 98 Answers
SOURCE: Fuel leaks from around the valve at the 5 gal plastic fuel tank
you twist the whole valve after disconnecting the hose...
get a new one and put it instead...
if u have any further questions let me know:
sal_kh_sab@yahoo.com
Posted on Oct 15, 2009
sal_kh_sab
  • 98 Answers
SOURCE: Need to replace fuel shut-off valve
well..the whole valve has a place where u can place a 12 or 13 size spanner...and then just twist it..
don't hesitate to write to me for further information:
Posted on Oct 16, 2009
H2_Brad
  • 425 Answers
SOURCE: Where do you buy the
Take the old valve, called a petcock, to a local lawn mower repair shop and they should be able to help you.
Posted on Jul 16, 2011
Gas grill no flow of gas
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Why wont my old grill work with new propane tank
Jul 13, 2014 | Weber Q Grill
1992 FXRS Dyna Glide. Gas leaking from overflow valve off the carburetor. Help please!
If it is a continuous flow the vacuum operated shut off valve is likely defective and not shutting off the flow from the tank when it should when there is not vacuum to keep it open BUT also the needle and seat are likely not cutting off the flow of fule into the float bowl as the float is not closing off the needle and seat assembly due to float or float setting problems and or a defective needle and seat.
Sep 07, 2013 | Harley Davidson FXDWG Dyna Wide Glide...
Hard starting--like not getting gas
probably fule pump check valve not keeping pressure after shut down. Try turning key to ON and wait 5 seconds before cranking. If this helps, it is the check valve. Replace pump in tank.
Oct 24, 2011 | 2001 Ford Explorer Sport
How do you change out a water valve in a aquastar 125b ng?
There are service bulletins concerning water valve rebuild and water valve retrofit that may be useful:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BTechSupport/ServiceBulletins/tabid/384/Default.aspx
From retrofit service bulletin:Old brass valve is replaced with improved plastic water valve.
Two sets of screws hold water valve against gas valve.
Descale water valve with CLR if it will not remove easily.
Call 800-642-3111 for help
Fix most tankless water heater problems yourself, same day for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Bosch Water Heaters
I have a 1985 Mercury Sable. It will run for awhile and shut down and after sitting for awhile starts back up I smell gas and wonder does the fuel filter or fuel pump needs to be changed
the fule pump is in the gas tank, if you hear it humming with the engine running, it's likely ok. Should have 40 psi if you check withg gage on scrader valve on fuel rail on engine.
Apr 01, 2010 | 1986 Mercury Sable
We have 99 Durango that will shut down while driving, fuel gage will show empty when tank is full.
It sounds like your fule pump is going out, this would explain the no gas on your gauge. You need to replace the fule pump assembly, this will come with a new fule level sensor as well. Hope this helped, if you need some tips on removing the fule pump just let me know.
Mar 10, 2010 | 1999 Dodge Durango
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Jan 31, 2010 | Watts Onan Portable Generator - 4000 ,...
The car cut off when i pressed on the gas and then i started it back up and when it cut off the second time it just cranks now
Could be fuelfilter or fule pump.or a fuel regulator.You may try taking fuel line loose at throttle body turn key to on and see how its pumping.The filter i believe runs cross ways in front of the gas tank.No need to take the plastic retainer loose to take it off
Jul 18, 2009 | 1995 Chevrolet Caprice
Car just shuts off, then restarts no problem
Run a fule system cleaner through ur car it goe into the gas tanks lol make sure u do it one a full tank if u are able to drive it that much
then when the tank is empty replace your fule filter its on the passenger side of the car mounted on the fram under neith the car..
im thinkin this will solve the problem for sure
the reason u wanna run he cleaner through it first is cause the old fule filter will catch all the nasty **** that hasnt already cloged your fule filter in the first place then u can take it off and pop on a new one.. remember to change your fule filter every 12,000 miles most ppl have never changed the one that was on the car when they bought it.
Jan 04, 2009 | 1996 Lincoln Continental
Coleman Powermate Powermate 5000W Generator Logo
37 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
