My mp3 player did not come with a charger. how do i charge it?
  • 684 Answers
If it has a inbuilt battery i think u can just connect it to the computer and charge it
Posted on Aug 03, 2008
mstr2kx
  • 102 Answers
SOURCE: mp3 player
Well, charging the battery alot may cause it to malfunction. So you have to charge your battery only when in is near zero (empty), and for no more than 8 hours depending on what device you use. Now your battery is dead, so you got to replace it. Goodluck
Posted on May 25, 2007
  • 3 Answers
SOURCE: regarding my mp3 player
Hi
you can probably buy a USB cable at somewhere like Tandy or Dick Smiths with the correct plug on the end to plug into your MP3 player. If not I would contact Samsung and see if they can sell you one and send it to you. YOu then just plug it into your MP3 and plug the other end into a USB hub on your computer and it should charge.
Posted on Feb 11, 2008
SOURCE: Philips GoGear SA3125/37 MP3 Player Charger cable
Anyway, if you have Motorola, you can use it charger for charging mp3 :) (My Aunt have Motorola mobile phone, and I used her charger for charging my MP3 :)) Sorry for weak English :P
Posted on Mar 13, 2009
  • 40 Answers
SOURCE: mine isn't a ZEN V Plus but it is a ZEN mp3
it could be the battery that is dead, however it is more likely that the chargers your are trying do not match the voltage needs necessary to charge it. just because a charger fits does not mean that it will actually charge it. LI-ion batteries are VERY picky and some can explode (literally EXPLODE as in bang, where did my hand go) if the wrong voltage is applied. here's the thing, most devices have a fail-safe built into them so that you cannot mess up the battery unfortunately the first charger you tried could have fried this making it unchargeable the reason the other charger works is because when a proper voltage is applied the power is split between running the device and charging the battery (this is cut off if too much power is applied) the actual battery takes very little power to charge you should look up the player via google and take not of the voltage and amperage needed to charge it these are important, there is a good chance it will still work. just buy the proper cable to hook it up to the PC this should charge it however that's not a guarantee the olympus mr100 for instance, would not charge via PC only with the dock and wall adapter. good luck and i hope this helps!
P.S. there is still the possibility that the bat. is fried and you may need a new one.
Posted on Apr 14, 2010
SOURCE: my sansa mp3 player wot turn on
hi my SANSA model: e260 is not working all :-( i got 2 charger and none still not working....should i get new battery ? or cable?
thanks
L.
Posted on Mar 31, 2011
I lost my charger to my mp3, where can I get a new one that doesn't cost much?
You can charge the MP3 player by connecting the USB cable to the MP3 player and then plug it into the USB port of your computer.
Jul 14, 2012 | Coby MP620 MP3 Player
Charging
MP3 players are charged via the supplied USB cable when it is connected to a computer. It can also be charged by a mains USB adapter charger.
Mar 15, 2012 | Asono Audio Players & Recorders
No power mp5 i use a cell phone charger in my mp5
What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Alternately you can charge it from your computer by using USB cable. It automatically charges when connected to a USB port
Dec 06, 2010 | JVC XA-MP51 (512 MB) MP3 Player ()
Nothing happened when i charged it up
Hi, What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
Hope it helps.....
Nov 29, 2010 | Audio Players & Recorders
Since I do not keep my computer on for long periods what kind of charger can I use for the Finis swimp3 player. Will a charger used for my blackberry 5v 1a be ok? Thank you. Sid
Yes you can, the USB cable is used for transferring music files to the MP3 player as well as charging the MP3 player. If your Blackberry charger has a USB socket that the MP3 player can plug into, then it will charge the MP3 player.
Jun 09, 2010 | Finis Swi MP3 Player
If I put to charge my mp3 in a regular
Of course it will damage your MP3 Player. Please use specific charger comes with MP3 players box to charge it. Other charger will damage your mp3 player & it will stop working.
Thanks.
Happy to help you.
Apr 24, 2010 | Audio Players & Recorders
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
Sep 27, 2009 | Audio Players & Recorders
Why is it not possible to charge the battery without PC
Have you got the right charger?? if yuo dont have the right charger for you mp3 player it may not charge the way it should i would recommend changing the charger or the cable.
Jul 09, 2009 | Philips SA5145 MP3 Player
Can my philips mp3 player use a sansa mp3 player charger
as long as the plug is the same yes you should be able to charge it, i know with my philips mp3 player i can use just about any mini usb charger from cell phones to car chargers to wall chargers
May 10, 2009 | Philips GoGear HDD1830 MP3 Player
The charger cable is sold by an outside company - Philips can give you the number for that company, or you can order it online.
If you already have a charger cable, plug the mp3 player into your computer - it will charge as long as the hold/lock switch is not engaged.
-Tha Mp3 Doctor
Feb 24, 2009 | Philips GoGear SA3125/37 MP3 Player
29 people viewed this question
 Grubhead
Grubhead
