Question about Cooper Industries Cooper Single Pole Switch W/pilot Light Ivory {12}
I keep blowing the breaker when i hook the switch up every time i turn it on. i have already put in a bigger breaker. this is an old house with old loop and bulb wireing.
    Scholar:
  • 143 Answers
If your breaker is triping you have a short somewhere if you have a meter turn power off and set the meter to continuiny or the setting to see if you have a open line if it has a beeping function that will work . you have three wires white-neutral black-hot green-ground . if you clip one lead to ground say on a metal box or the ground wire and with the power off you should get a beep with the neutral wire but the hot side should not beep if it does it means it is shorted to ground and you have to trace it from there to find the proplem a bigger breaker will not change the problem please write me back if you need more help will talk on phone to run you through problem
Posted on Mar 26, 2011
E315 cerwin vegas speakers and one keeps blowing a fuse when I turn it up to the normal volume I play them.Can I use a bigger fuse or is it the speaker?About a yr old rarely used until the last few mo
Try playing the speakers at a friends house or something to see if you blow their fuse. If you don't then you know for sure that you need a bigger fuse, but if you do then it's the speaker.
Jun 03, 2013 | Audio Players & Recorders
A/C keeps tripping the meter box, if i reset trip switch A/C works fine for abot 20mins then trips again.purchased Dec 2008
Replace the breaker in the house circuit it is probably weak, make sure you replace it with the correct size and don't be tempted to go bigger unless your confident that your wiring is good and can handle a bigger breaker. If the breaker continues to trip you may have a fan that is bad and drawing too many amps
Jan 26, 2011 | LG Heating & Cooling
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
Pushmatic breaker keeps tripping everytime I hit
You have it shorted out somewhere along the line. If it is a light switch you are switching, what have you done lately to make this trip? Anything? You might have a bad breaker. You can check it by shutting off the power, pull the wire out of the tripping breaker, put it in another breaker, turn the power back on, switch the breaker on, then hit the switch and see what happens. If it snaps off, it is not the breaker, but the switch, the wires in the box, or the lights, or something along the line, you will have to check each one. New construction has made all lights and all receptacles separate, so if your house is old, you might be looking at receptacles too. Check anything plugged in to an outlet, make sure there is nothing shorting. Hope this helps.
Apr 03, 2010 | RTO Pushmatic 100Amp 2-pole circuit...
I am visiting my mother in law. She has a circuit
what else is on circuit with microwave and as to grafted is that a hard wired hook up if so breaker may be to low depending on how old the unit is but before replacing it i would check microwave draw and find out if anything else is on circuit
Jan 25, 2010 | Bryant Electrical Supplies
As i turn on microwave it blows the fuse. what could be the reason.
try using it at a different location in the house(different circuit) if it also blows that fuse, there must be a short in the unit. do not use. if it works means line in the kitchen is overload, and you need a higher fuse rating or breaker.
Sep 10, 2009 | Microwave Ovens
Circuit breaker popping when stove top/ oven is on
thats how fires start when fuses keep blowing. Just use one at a time. Its probably over loading the fuse you may need a bigger fuse block. Call a local handy man if you havent already
Jan 03, 2009 | Kitchen Ranges
House has old wiring,going to be knocked down in 2yrs,1 part of lighting circirt keeps blowing fuse and knocking the trip off,every time I put trip on,in 20seconds it goes of again?
This would sound like an overload on the circuit. If it were a direct short the breaker would trip immediately. As an example if you had two units such as a refrigerator and a freezer on the circuit in question, both motors starting at the same time could draw enough current to trip the breaker on start up.
Jul 11, 2008 | Heating & Cooling
Cooper Industries Cooper Single Pole Switch W/pilot Light Ivory {12} Logo
137 people viewed this question
Top Cooper Industries Electrical Supplies Experts
john h
AJMAL KHAN
Gene Haynes
Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
