Question about Poulan "" Push Mower
After i start my mower it runs for about 10 sec then it turns off.
  • 252 Answers
Replace the plug isand make sure sure spark is constant -clean the air filter check that you dont have water in the fuel tank / or a blocked fuel pick up tube or main jet in the carby
make sure flywheel key is not sheared this will be evident by a kick back when you try to start
sounds like compression is all good
have a look and let me know how its goes
cheers pauly46
Posted on Mar 26, 2011
Joystick troubleshooting
Is gas getting to the carb? Try blowing air back into fuel tank and listen for bubbles. Also check on cogged fuel filter.Rubber in fuel pump?
Aug 15, 2014 | Snapper Garden
Tip
Gm cars and trucks with security light on, veihcle will not start,stall after a...
a relearn of the key may help and is done with the ebrake up to keep the day time running lights off . put key in the ignition and turn it to the on position right before crank for 10sec. turn it off for 10 sec. then turn it back on for 10 mins. repeat two more times back off for 10 sec.and then back on for 10 mins. it iscruishle you try to keep with in the times or very close. 10 seconds and 10 minutes three times and that will relearn the key.
this will work for passlock 2 systems and newer.
on Jan 04, 2010 | Chevrolet Corvette Cars & Trucks
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
Start and ran the mower for 10 min Shut it down and now can't get it running for more than 10 sec. Changed the gas drain the old gas Changed the spark plug, cleaned the filter as stated. still can
Tecumseh engine right? Pull the float bowl off the carb. I suspect some water contamination. while it is off clean the jet holes in the nut. They may have varnisized gas in them. contact me with any more questions.
Sep 13, 2012 | Yard Machines Garden
1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
Apr 21, 2012 | Cub Cadet Garden
4-stroke mower will not start, stay running.
sounds like your float in the carburetor is not letting fuel in fast enough. i would take the float bowl of and see if it moves up and down freely and turn the gas on to see if much volume of gas flows out the needle.
Apr 09, 2010 | Garden
When starting car, takes 8-10 sec to turn over.
Do you mean 8 to 10 seconds to START? Turn over means the engine is turning or cranking BUT starting is when the engine is actually running. I think you might have a fuel problem like your loosing your prime. Turn the key off wait 15 sec. then turn the key ON not cranking it repeat this (3x) if the car starts immediatedly your fuel pump is loosing its prime or the fuel pressure regulator is leaking.
Jul 13, 2009 | 2001 Isuzu Rodeo
Lawn hog electric mower
Sounds like the brushes are bad .or you have a direct short.
Aug 30, 2008 | Black & Decker 19" Electric Lawnhog...
Poulan "" Push Mower Logo
52 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
