Question about Whirlpool GHW9150 Duet Washer
GHW9150 will not start, door will not lock. No codes on display Has power and water.
  • Sean Miller Mar 26, 2011
    Does it beep when you hit the start button or do you get any response at all?
    Sean
  • jwiesehan Mar 26, 2011
    Nothing and no codes,
    Thanks
  • 552 Answers
This means that the CCU on the rear of the washer has an electronic glitch. Try unplugging the washer for several minutes if this does not work the CCU would need to be replaced.
To do so remove the top of the washer. Three screws hold it down. The ccu is on the top of the washer. Remove the wires and place on new.
Let me know
Posted on Mar 26, 2011
Testimonial: "Thank you, I will uplug machine.If this does not solve the problem, next step, replace the circuit board. "
  • bnickolaus
    bnickolaus Jul 05, 2012
    I was able to remove the top cover and wiggle the connections between front led and the power source; much like a motherboard connection. worked like a charm.
  • bnickolaus
    I was able to remove the top cover and wiggle the cord connection from the front LED panel to the box it initially connects to. Worked like a charm.
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Door lock
These fault codes are caused by a failure of the main control circuit board (the brain of the washer), this is the board that is behind the washer control buttons.
Feb 07, 2012 | Whirlpool GHW9150 Front Load Washer
We have a Samsung front loader. Model # WF328AAIWIXAA. We started the machine to do a load, and later we were going to transfer the clothes to the dryer. It appears to not be getting power. We cant open...
Is the display (User interface) is lighting up and on. That means you are getting power.
If display on and cycle stopping at mid cycle and cannot open door.
If the machine water level sensor detects sufficient water in the machine it will tell the control board not to release the door.
Is there is water in the machine. May be your drain pump is clogged. Does it give a error code on display.
Don't force open the door. You will break the lock and you will need $ 200/= parts and labor to change the door lock
Call a local service guy
Oct 25, 2017 | Samsung WF337AAL Front Load Washer
I'm getting error code FL when trying to start my washer. It will start to fill with water and then error. Please help! It seems like the door is locked.
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 23, 2011 | Maytag Neptune MAH5500B Front Load Washer
I HAVE A WHIRLPOOL WASHER GHW9150PW3 FRONT LOAD WASHER AND THE CODE F 05 IS BLINKING
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the “F/05” error code
will be displayed.
2. Check the water temperature sensor. Refer to the
“Water Temperature Sensor” section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
Or just call service! (:
Feb 16, 2010 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet washer will not start . Hear a clicking noise then receive DL F fault
The clicking sound is coming from the door lock/switch assembly trying to lock the door but it cannot. After six trials, the error code "FdL" shows up on the display. Press PAUSE/CANCEL button twice to clear it.
The only way to fix the problem is by replacing the door lock/switch assembly with part numer 8181700 and costs about $40-$55. Some vendors listed it as part number 1094190 or PS972231. Below is the replacement procedure.
Door Lock/Switch Replacement Procedure
  1. Unplug the machine and open the door.
  2. Stretch the retainer spring of the seal boot retaining hoop then remove it. The seal boot is the gray rubber around the door opening. The retaining spring is located at the bottom of the door opening. The door lock/switch assembly is located on the right side of the door opening.
  3. Ease the part of the seal boot off the lip of the door opening near the door lock/switch assembly. Remove enough of the seal boot to gain access to the door lock/switch assembly behind the front panel of the washer. Be careful not to tear the seal boot because it will cause water to leak from the tub.
  4. Remove the three screws securing the door lock/switch assembly to the front panel.
  5. Lift the door lock/switch assembly and pull it away from the front panel then pull it out of the machine.
  6. Disconnect the wiring harness connector and connect the new door lock/switch assembly.
  7. Reinstall the new door lock/switch assembly and the seal boot in reverse order of the procedure above.
Jan 20, 2010 | Whirlpool GHW9150 Duet Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
I hope this helps you.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool Duet Washer GHW9150PW1
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Mar 04, 2009 | Whirlpool GHW9150 Front Load Washer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Ghw 9150 lock mechanism problem
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Oct 14, 2007 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
171 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
