Question about Jensen VM9410 Car DVD Player
HOW DO I BYPASS THE EMERGENCY BRAKE WHEN INSTALLING A VM1412
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 08, 2008
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
I dont know whats wrong with my valor 169T dvd player i can hear it but i cant get to see it in my monitor
You have to disable the emergency brake bypass. From what I remember there are two wires on the back of the radio one for the brake and one for the emergency brake. One of the wires is a blue yellow and the other one may be a light green. But you have to trigger the brake wire twice and trigger the emergency brake wire once in order for the video to play. The brake has a positive trigger and the emergency brake has a negative trigger.
Mar 10, 2011 | Alpine CVA-1003 Car Video Player
How do I bypass emergency brake so the dvd player in my car works
This is against the law and you will be fined if stopped by the police
May 19, 2010 | Car Audio & Video
How do I bypass the emergency brake on my Eclipse AVN 7000
You will have to connect the brake wire which is pink to the the ground wire.
Apr 27, 2010 | Eclipse (AVN7000) Car DVD Player
How do i bypass emergency brake wire on my clarion to play movies
connect the wire to a ground/negative point, please note this is a saftey feature.
Nov 15, 2009 | Clarion Car Audio & Video
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
Bypass emergency brake switch on 92 Legend w/Kenwood DNX7100
ground the green emergency brake wire just hook it into the radio ground and that will fix it
Nov 29, 2008 | Kenwood DNX7100 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Jensen VM9410 Car DVD Player Logo
87 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
