Question about Dell Dimension 1100 PC Desktop
I cannot find if it's possible to boot from USB for a Dell Dimension 1100. I am trying to restore a computer and the CD Drive has failed, so my primary objective is to load Linux via USB so I don't have to buy an internal CD drive. The BIOS boot sequence has nothing in it about USB, but is it still possible? Thanks.
  • rocsoundman Mar 26, 2011
    I'm online on my laptop/phone. This desktop is a side project of mine. Unfortunately, because my household is strictly laptop based, that won't work either, so I'm left with the option that I figured I would have to do (but hoped there would be a working alternative) in buying a drive.
    Although, now that I think about it, I could pull the hard drive, put it in an external enclosure and format/install Linux that way, and then stick it back in the desktop.
    Umm...the comment I posted disappeared, so I'll try to repost it as close as I can.
    I'm online because of my laptop, phone, and tablet; unfortunately, because of being a strictly laptop-based household, I can't try your other option either, but you did give me an idea for a work around until I buy a new CD/DVD drive.
    I can pull that hard drive out and put it into an external enclosure I have lying around, reformat it, and install Linux on it that way.
  • 902 Answers
If you go to dells website and flash your bios with the most recent version it should give you the usb option and make sure your usb stick has been format to become a bootable drive
Posted on Mar 26, 2011
Testimonial: "Posted an idea that I hadn't thought, and even though the idea wouldn't work in my case, still provided other options to help me fix my problem!"
  • 1 more comment
    How would you suggest I go about doing that since part of my restoration means that I'm having to work with an unformatted hard drive and no internet access on that tower.
  • brian shevack Mar 26, 2011
    how are you online now? i would download the bios update and unfortunatly take out your hd you have now and put it in the computer you are using as a secondary hd and install the bios that way. since usually flashing a bios would require you to use that exact computer. you can also spend 20 dollars and buy a new dvd drive (annoying i know) since and external wont help (no usb boot option)
    glad i could help external enclosure was my next idea lol
    President:
  • 1,623 Answers
When you first turn on the pc press F12 then select the usb to boot from
if you found this info useful please vote for me
    I've already stated that the USB option is not part of the boot sequence within the BIOS.
Dell Dimension 1100 PC Desktop - restore to factory settings
if it comes with windows 7 or vista you can try and tap f8 until you get a boot menu and there should be an option to repair your computer, if it's windows xp you're kinda screwed unless you can access the recovery partition.
Feb 15, 2012 | Dell Dimension 1100 PC Desktop
Hi, I have a Dell dimension 2400 desktop. I plugged in a (wiped securely) hard drive. After it loaded the DELL LOGO BIOS, it shows a blank screen with a " dash -" on the top right corner. I...
try tapping the F12 key over and over when you see the DELL Screen to bring you to the boot menu....with your CD in choose to boot from the CD and it should allow you to run the OS installation from there.....your machine is trying to boot from the hard drive that has no OS on it.
Mar 29, 2011 | Dell Dimension 2400 PC Desktop
Running Windows XP Home Edition Error code
The diags code was a failed response from the floppy drive. Most system didn't ship with one.
Boot to the XP CD, go to recovery console, run bootcfg /rebuild
http://support.microsoft.com/kb/330184
May 18, 2010 | Dell Dimension 8400 PC Desktop
I crashed my dell and need to re-intall windows
there is a particiam on your dell that has all the restore data on it do you have the restore disk insert it and go. you will loose all the data that is on the comp when you do it. if you need that data pull the drive and put on another comp and copy it off. the reinstall it and then restore it. if you dont have the disk contact dell for a replacement.
Jun 27, 2009 | Dell Dimension 1100 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Computer does not boot
O.k. so I gather your trying to reinstall windows. There's a few possible solutions the first of which is to reseat all connections checking for dust or anything else which might be between the connections. Second is to check your bios (by hitting usually f1,f2,f10,f11, or delete or esc keys) and making sure its set to boot from your cd\dvd rom. Also make sure your cd\dvd isn't scratched or dirty. If those fail try another CD\DVD rom drive to make sure it is the drive that has the issue. Don't be so quick to trash good hardware ;) good luck
Mar 26, 2009 | Dell Dimension 4600C PC Desktop
Multiple viruses on a Dell Dimension 1100
Formatting your hard-drive is the easiest way to eliminate anything on that hard-drive. Follow my steps below to do just that.
Start your computer so you can open the CD-ROM drive. Insert the Windows Installer into the CD-ROM drive. Close your CD-ROM Drive. Shut down your computer.
Now start your computer and while your system starts up look for an option for the, "Boot Menu" or, "Boot Device." It will have a key associated with it that you have to press continually for you to enter the menu. For instance:
(F8) Boot Menu.
Here's a hint to help you out. If you see the loading screen of your operating system, you've missed your window. Restart and try again.
Now just to clarify, we're not out to change the boot sequence, we're trying to boot from a specific device. Once you find that menu select your CD-ROM drive and press enter. It might ask you to, "Press any key to boot from CD-ROM drive." As it mentioned, press any key. Afterward the Windows Installer will launch.
Follow the directions on the screen to set up Windows. Yeah, it will warn you that there is another OS installed on your primary Hard Drive and that it might be better for you to, "Repair" your system. Ignore that and continue with the process to Install Windows. Before the final step to install Windows there is a screen that allows you to partition your hard-drive. In this are, erase ALL partitions. Afterward create a new one which will be your C:\ drive. If you want to partition your drive further, go ahead. However, at this point you can continue the Windows Installation and the Installer will ask you if you want to format with the NTFS or FAT32 type. Format with the NTFS type.
Now the Windows Installer will erase EVERYTHING on your hard-drive and proceed to install Windows XP.
Feb 06, 2009 | Dell Dimension 1100 PC Desktop
Restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
Jul 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Restore hard drive and wipe out everything on it
Dell always send with a new computer one cd to restore the OS of the computer.
If you have this CD put it into the CD drive and boot the computer, follow the instructions on the screen.
Or put an windows CD into drive and boot the computer.If you use this second option you will have to download the device drivers from dell support page.
Best regards
Dec 19, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 1100 PC Desktop Logo
384 people viewed this question
Alun Cox
