Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Our electronic options are not working. We have to always wash heavy and sanatize for it to turn on. how can we fix this? Before this happened, the dishwasher would make loud noises in the normal setting.
    Sergeant:
    Champion:
  • 202 Answers
Hi... you need a new touch pad
Posted on Mar 26, 2011
How to disassemble atf6000fs?
Hey friend, I appreciate your for the post!
I understand you are trying to disassemble your Frigidaire washer, ATF6000FS. I have researched your error code "E90" and that seems to be an issue with your main control board or user interface board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Aug 07, 2014 | Frigidaire ATF6000FS Affinity 3.5 Cu. Ft....
Why won't it run
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic board.91d0c2b1-1baa-49b9-9f99-f6a86f3b29df.jpg
Sep 29, 2013 | Frigidaire Gallery FGBD2451KB Full Console...
Parts of the clay
Did you mean parts for the machine, Click this link: Spares
Jan 23, 2013 | Frigidaire ATF6000FS Affinity 3.5 Cu. Ft....
My frigidaire wont spin or wash
Remove the 2 screws on the top panel and remove the panel. Check the wiring connections on the control board.
Nov 11, 2012 | Frigidaire GLTF2940FE Front Load Washer,...
Power steering fault appears periodicly
The electric power steering units are just a problem waiting to happen, they sit close to the road and contain electronics that can't get wet but often do especially in areas where you may have to drive through heavy rainfall. There are not a lot of options unless you can locate someone dismantling a vehicle that you can buy parts from.
Mar 10, 2012 | 2006 Honda Civic 2.2
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
When I set it to normal wash it takes more than a hour to finish I also press all the other settings dry heat, sanatizer. dont know if I'm doing something wrong
Every setting extends the wash time. You only need sanatizer if your doing a lot of baby bottles. The normal cycle with the strong dishwasher detergent will kill all bacteria anyway. The dry heat extends the time even longer and uses more hydro. Just open the door when the cycle is finished and they will dry on there own.
I hope this is of some help.
Dec 31, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
Food Deposits left on dishes
I had an old machine with a similiar problem & I found that food had somehow entered into the arm that spins & sprays out water. The food blocked somewhat the holes which of course means less cleaning.
Mar 05, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Jan 17, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
152 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
