Question about NIB Scattergories/nib/red Box
Scattergories timer-need to put back together
Software plays but shows no picture
Late, but the answer that works for me.
Run Compatibility Mode win 95 or win 98/ME.
Edit the shortcut. Edit the Target.
Add -window after the existing text in Target.
e.g.
"C:\Program Files (x86)\Hasbro Interactive\Super Scattergories\Scattergories.exe" -window
Apr 16, 2013 | Hasbro Interactive Super Scattergories for...
I have the disk super scattergories and I want to load on windowsxp. It doesnt do anything
Microsoft Windows 98 was an operating system used on a majority of personal computers from 1998 to 2000. Because of this, there are a variety of games available to play on Windows 98, but are incompatible with later versions of Windows. If you have Windows XP or higher, you have access to a "Compatibility Mode" that allows your computer to play those games. Activating compatibility mode is a simple procedure.
Right-click the file that you usually click on when you are trying to start a game.
Select the "Properties" option in the drop-down menu.
Select the "Compatibility" tab, then check the "Windows 98" box.
Select the proper video mode for your game under "Display Settings."
Select the "Apply" button to save your settings, and select "OK."
Double-click on your game's file to begin playing the game.
Oct 07, 2011 | Hasbro Interactive Super Scattergories for...
I havea Gardena C14e Water Timer and I took it apart to try and repair a small crack close to where the water enters from the tap. However after putting it back together the water now runs through it? Do...
Some Gardena manuals on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
If manual is in another language, use google translate.
I have not heard anyone on fixya report they were able to repair Gardena water timer, or any cracked water timer.
If you find successful fix, or find seller of parts, then add a comment to this thread to help others with same-similar problem.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | GARDENA Water Timer
HOw do I repair the Scattergories timer?
Hi. I hope you've found an alternate timer to use, if you haven't figured it out elsewise, in the meantime. I came across this link: http://myeclecticrandomness.blogspot.com/2011/11/how-to-fix-scattergories-timer.html while looking for the answer myself. It appears there may be different models, as the one featured in this link shows hooks at ends of spring whereas mine does not have these. Thus, I've had a little more difficulty getting things all aligned and working properly, but that is no fault of these instructions, which include the steps and real pictures. Good luck! and good gaming.
Jan 15, 2011 | Toys
I have a utilitech 7 day in wall digital timer and would like to install it but have no clue how to. can you get me started
You want to install Utilitec in-wall 7-day timer that has 4 wires: red, white, black and green.
You are replacing a single pole switch that controls a light or several lights.
There is not a second switch that controls same lights.
The switch has 3 wires.
Generally there are two insulated wires and a bare ground wire.
Add a comment any time.
Here's what to do:
I have tested these timers for wiring and programming.
Get started and instructions will make sense as you go.
Turn off circuit beaker to switch.
Remove old switch.
1) Timer-green-wire connects to bare ground wire using one of the yellow wire nuts included with timer. Put two wires together so they are even at ends. Put wire nut over wire ends. Rotate wire nut clockwise between fingers until very tight.
2) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire using two more yellow wire nuts. Choose either one for now. You may have to reverse these two wires in a minute.
3) In back of electric box are white wires twisted together and covered with wire nut. Remove the wire nut, but do not untwist the white wires. Connect timer-white to these wires. Then put original wire nut back over white wires.
4) If electric box does not have white wires described in step 3, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires from step 2.
If you need help programming 7-day Utilitec timer. Pages have bigger print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Super Scattergories compatible with Windows 7
julyallan01_33.jpgMaybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Jan 16, 2010 | Hasbro Interactive Super Scattergories for...
My Kenmore dryer heats as it should but the timer dosent move and the dryer stays on.
This is a common problem. Dryer timers are advanced by a motor that turns gears and moves the dial (and internal switching) forward. The timer needs to be repaired or replaced. More than likely the latter since most timers are riveted together and cannot be repaired (unless you're someone who can put a geared jigsaw puzzle back together without any instructions since they normally fall to pieces when opened). I have tried to repair some timers and have been marginally successful, but to have a piece of mind, order the part, have it replaced (wire for wire when the unit is unplugged from the wall). If the timers look different, it is still possible that they gave you the correct timer. Verify that the new and the old timers have the same letter and number markings on each of the wires.
It is best to label the wires as you remove them from the old timer with a piece of tape and a sharp pointed marker. That way there is no question which wire is which.
Hope that helps you.
Nov 03, 2009 | Kenmore Dryers
While playing hasbro scattergories game shuts down
If you're running windows Xp/Vista/7 this game isn't designed to run on it. This game was originally made for 98/ME and compatibility mode doesn't seem to get it to work.. if it does work it doesn't work for long. Personally, I think it's for FAT32 file systems .. not NTFS
Jun 15, 2009 | Hasbro Interactive Super Scattergories for...
Timer knob assembly, how to disassemble and assmble back together
It sounds like the only thing you are missing is the circlip to hold the whole lot together.
With it de assembled you should see a cut out part on the timer stem that's where the circlip goes when it's all back together
Jun 11, 2009 | GE Washing Machines
NIB Scattergories/nib/red Box Logo
380 people viewed this question
Top NIB Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a NIB Toy Expert? Answer questions, earn points and help others
