I have Pioneer Project 100B speakers, the woofers are10", labled W525 1974. The magnates are approximatly 90 oz. Thought I might build a sub with them so I'm trying to find the specs. Thank You Greg PS Do you think they would work well as a sub?
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
connect to same terminals as front speakers, this will also cause reduced volume from front speakers. (as per owners manual)
Posted on Nov 19, 2007
SOURCE: SPEAKER CONNECTION
problem with connection
Posted on May 08, 2008
  • 120 Answers
SOURCE: sub woofer pioneer VSX-D412 5.1
you have a bad cable
Posted on Jan 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
  • 60 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
I puchased a pioneer vsx-820 receiver yesterday , i have a sub- woofer that only connota via speaker wire ends how can get this to work?
I have the same problem, your sub-woofer is passive and you need a powered sub-Wfr, more money is the only FIX!
Dec 16, 2010 | Pioneer AVIC-D3 Car DVD Player
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
73 people viewed this question
 Grubhead
Grubhead
