Trying to help someone who has a sentimental attachement to a mag xistor radio, model 1R1006. price no object.....
  • 902 Answers
What do you need help with?
Posted on Mar 26, 2011
It appears to run when turned on, lights, clock, turntable, everything, but does not heat, defrost or anything.
The heating unit in a microwave is called the Magnetron. It is similar to a large radio tube in a sense. It could be bad or some of the other components that feed it the power could be bad. Some of this area is Hi voltage so it is not an area the average person should be trying to fix. Most companies have 3 to 5 year warranties on the mag tube so you might want to look into that. It is expensive to replace. price for the Mag itself range from $70 to 150 dollars just for the part.
Apr 03, 2015 | Microwave Ovens
Mag One BPR40 not powering
Contact Motorola Solutions (http://www.motorolasolutions/support)
Jun 26, 2014 | Motorola Mag One BPR40 Two Way Radio
What is the value of a 1993 zenith tv 26" screen
Not a whole lot, to say the least. However, objects with sentimental values or heirlooms are priceless.
Nov 26, 2013 | Zenith Televison & Video
I bought 2 Motorola bpr40 Mag One radios, but one is used and their channels do not match. How do I return them to factory defaults?
The BPR40 is only programmable by Motorola proprietary software. The easiest method for programming them to match one another would be to take them to a dealer. Prices vary, so you might want to call around and price check your area dealers.
Best regards.
Feb 09, 2013 | Radio Communications
Mag One Radio - Static
If your BPR40 radios are all about the same age, it could be a sign of your batteries getting old and needing replaced. A bad or weak battery will cause the radio to exhibit static, and then eventually poor or no transmit. Check your battery date code first, it is a 3 digit number on the battery label, followed by a space and then usually a number 1. On the 3-digit code, the first number is the year, the next two the week of the year. 229 would be 2012 the 29th week. Replacement batteries should be available for around $35.
If you feel the battery is not the issue, you may have ONE radio which is causing the problem. Try using all your radios and testing by shutting off just one radio at a time. You may identify the culprit. Motorola offers a one year warranty on the BPR40, after the warranty is done, flat rate repair is typically available for $69.
Third possible cause is some type of interference in your area. If this is the case, your radios may need a PL code programmed into them, if you don't already have one. This will filter out unwanted noise or transmissions. Sidenote: If you've added any new computers or electronic office equipment recently, it may also interfere. Some foreign produced computers will lack the filters required in the USA to prevent interference with communications. Coiling excess cables can be helpful in stopping RF noise.
The second of static at the end of your transmission is called "white tail" and is common in all modern radios. There is a programming feature to eliminate most of the white tail noise, it is called reverse burst. Your radio dealer can reprogram your radios and add this to your radios, or future radios you buy. The trade-off with reverse burst is that you will loose the last of your spoken words if you do not hold your PTT an extra moment, as reverse burst actually transmits back or cuts off the end of a transmission to eliminate the noise. White tail is worse when mixing old model and new model radios together.
Best regards.
Jul 12, 2012 | Motorola Mag One BPR40 Two Way Radio
Thanks ,when i turn on my system from standby the bass unit makes a horiffic crunching eletric buzzing noise and i have now noticed the fan (not working) but im not sure it has to heat up before kicking...
I can understand sentimental attachment.
The symptom you describe could be something as simple as a "dry" soldered joint but finding and rectifying it, if indeed it is only that, needs a deal of experience and knowledge you clearly do not possess and learning on a treasured item is not advisable because getting it wrong can cause a great deal more trouble.
I suggest you look in your local classified directory for a suitable repair shop - there is usually a few in every locality repairing tv, radio and audio equipment, in-car entertainment and general electronic repairs. Most people doing that sort of work are cheaper than official dealers and use cheaper parts, yet many of them began by working for the bigger brands.
Mar 23, 2017 | KEF Audio KIT100 System
Does a MAG monitor model 900P have in built speakers?
Yes the Mag 900P has built in speakers. The audio lead for them is attached to the blue VGA connector and has a green tipped plug like a set of desktop speakers.
Oct 10, 2010 | Mag Innovision LT776s 17" LCD Monitor
Replace dial cord on GE Portable AC/DC Radio Model # P4960A
See photo album:
http://www.flickr.com/photos/goggomobil/sets/72157623454498101/
Jun 02, 2009 | GE Audio Players & Recorders
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
13 people viewed this question
 Grubhead
Grubhead
