Nec nfl 1065 front loading washing machine has error code LE will not fill with water
  • 1314 Answers
SOURCE: kitchenaid front loading washing machine
check your drain hose see if its too low lower than the tub or too far down in the drain as this will cause a siphon action
Posted on Mar 02, 2008
JULIANFIX
  • 975 Answers
SOURCE: the water wont drain out
YES ! there is something else , check the little MOTOR that is attached to the drain hose , take it out , take it apart and check if there s some stuff blocking the motor inside ,hopefully this will take care of the problem .
Posted on Apr 17, 2008
  • 636 Answers
SOURCE: How to open door on front loader when unbalanced.
unplug the unit for a couple of minutes and try it
Posted on Jul 26, 2009
  • 4090 Answers
SOURCE: LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Posted on Aug 11, 2009
Testimonial: "Thanks!I've already tried &didn't work. As soon as water fills up, instead of start washing, it makes the high pitch sound and "LE" somes up.Oh No...!"
  • 7 Answers
SOURCE: nec nw-452 washing maching gives
The lid switch is faulty and needs to be replaced or bypassed.
Posted on Oct 09, 2010
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code LE
The "LE" error occurs when a Samsung washer is in the process of filling but cannot reach the required water level. In most cases, there is an issue with the washer's water inlet hoses. Check that they are installed properly and there are no kinks in the hoses.
Nov 25, 2012 | Samsung WF337AA Front Load Washer
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
LE error code
Hope this helps.
Error Code Condition
Error Code IE Condition Inlet water supply error
Error Code UE Condition Unbalanced load
Error Code OE Condition Drain error
Error Code FE Condition Water overflow error
Dec 16, 2017 | LG WD14311RD Front Load Washer / Dryer
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Error code LE Front load washer about 4 years old. This is the first time we had an issue with it. My wife called me and said the water filled but that was it and the error code said LE. This was after she...
That error is a Lock Motor Error. First thing I would do is to replace the hall sensor and check for loose connections going into the hall sensor as well as the main board.
Dec 05, 2009 | LG Washing Machines
Aug 11, 2009 | Washing Machines
How to open door on front loader when unbalanced. Nec Nfl 1065.
Jul 26, 2009 | Washing Machines
The water wont drain out off the washing machine there is an error code UE is flashing and it wont finish spinning i have taken off the drain pipe and its not blocked and i have emptied the water via the...
Apr 17, 2008 | Washing Machines
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
