Hello I have a Rosewill rnx-ezn4 wireless modem and it is currently an unsecure network, with no need for a password and I would really like to put a password on it to make it a secure network, and I am not even sure where to start, Please help! :) Thank u very much
  • 436 Answers
Here is the link to download all the info you need.
http://www.rosewill.com/support/download.aspx?ids=3_39_112_1281
good luck!
Please rate FIXYA
Posted on Mar 26, 2011
Installed, great signal, won't stay connected, blinks on and off
Try reinstalling the drivers. Get an external powered usb hub and plug the adapter in to the hub. Get a cable to move the adapter away from your computer. Turn off all phones near your network adapter. RNX N1MAC
Jan 24, 2014 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
Adapter shuts off during restart.
What is the make and model of the computer and what operating system is on it?
Nov 26, 2013 | Rosewill Rnx-N250pc2 300mbps Wireless...
How do I secure my wireless and add a password?
hi, I think you may try WPA2+AES setting while setting up wireless connectivity, it will ask network key to setup. It is more secure setting for wireless usage.
Sep 03, 2012 | D-Link (DCM-202) Modem
I have the RNX-N1MAC wireless adapter and just recently it has started dropping internet connection. It stay connected to the wireless and shows full bars, but pages won't load.
1. check the manufacturers web site to see if there is an updated firmware for your adapter.
2. check your wireless router to see if you have to update the firmware ( this is is you are using this adapter on your home network
Jun 17, 2011 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
Which program do i use to install a rosewill rnxni on my windowsxp
Hi, Lester.
Here is a link to the driver downloads for your wireless adapter.
http://www.rosewill.com/products/d_1126/productDetail.htm
Click on the tab for downloads, and then select the driver download for your operating system.
There is more than one version available for your device, I would go with the one that's listed as V1.5.1
That is the most recent version available.
I hope this helps you out.
Also, the manual is also available for download off of the same page.
Good luck with your download and installation, and have a good day.
May 30, 2011 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
Window 7 32bit wireless could not connect or detect the wireless LAN with Rosewill RNX-N2LX b/g/n adapter. No problem with Window XP I downed load the latest driver but it still could do the job. ...
Install the driver then reboot your Windows7 system.
Plug the wireless adapter into a USB port.
An install icon will appear in the systray showing that it is installing the driver.
Click on the install icon and stop it from finding a driver in the Windows data base. Apparently Windows finds a driver and installs it corrupting the Rosewill driver.
I tried using the wizard but it locked up. After rebooting the system the adapter found my AP and I was able to log in.
Jan 24, 2011 | Rosewill RNXN2LX IEEE 80211bgn USB 20...
I was told via the internet that i could hook up my Samsung blu ray player using this wireless adapter I can not get it to work, I have a Belkin wireless router that i was hoping it would recognize it and...
I would first remove the Security off the router completely and then make sure the device can connect without any
security - IF it connects OK, then at least you know the wireless works all OK with the device Next, add the security back on, - Make sure the device does support the type of security you are using - WPA2 needs
special hardware to work - so you could start with WEP, or WPA It may also be a conflict with other wireless signals - like cordless phones, although, I would suspect that effects all
devices - But it maybe worth changing the wireless cahnnel used in the router - to avoid interference download and run
this program on a PC http://www.xirrus.com/library/wifitools.php Then run the program - If you get an error - You need [URL="http://www.microsoft.com/downloads/details.aspx?
FamilyId=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en"]NET Framework[/URL] installed for the WiFi Inspector to
function. Look at the wireless signals in your area and what channel they are using and the strength of the signal - where possible
try to use channel 1 or 6 or 11, as they do not overlap other channels If still an issue please comment back, and i will look into further
Apr 03, 2010 | Rosewill Wireless Adapter RNX-N1MAC IEEE...
How do I set up this modem as a secured network .
Is your modem wired or wireless?
if it is wired you donot have to worry but if it is wireless and the network is unsecured you need to perform the following steps.
if your computer is using the same wireless connection then you will loose the internet connection wirelessly as you will need to setup the configuration with the computer again..
1st u need to find the ip address of the computer..
click on start,then click on run in the box type in cmd and hit enter
now you will see a black box in that box type in ipconfig and hit enter
out of all the results you will see something which says default gateway there will be numbers beside it make a note of those number(eg it will be something like 192.168.1.125..this is just an example)
go to the browser page and type those numbers in the addres box,
it should open a user name and password box,type in admin/admin as the user name and password,
there you will see a tab for wireless under that tab you will see the option for security and then you need to make it secured..
YOU CAN TELL ME WHO IS THE MANUFACTURER OF THE MODEM SO THAT I CAN EXACTLY TELL YOU WHAT YOU NEED TO DO....
vedhick
Feb 04, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
