Question about LG WM1812C Front Load Washer
The washer turns on, fills with water, and then stops, then an LE light comes on. I drain the water and try again and the same thing happens.
    Scholar:
  • 116 Answers
Hi this is an error for a motor/stator error. You will probably need a new motor/stator, this comes with a new rotor sensor, this will fix the problem.
Sean
Posted on Mar 26, 2011
What is the probable cause of an LE code?
Most washers give it a certain amount of time to fill up with water and if it doesn't sense it has filled up with enough water after that time it will stop the washer. This is done as a safety so your washer won't flood your house. First thing to check is that the washer is filling up with hot and cold washer correctly, and that the water is coming into the washer at a good rate. The hot water valve has one solenoid, but the cold water has three solenoids (more to go bad). A clogged or failed water valve is the most common thing that we see cause this type of a problem.
Water level drops below the reset level during the wash or rinse portion of the cycle. Check for leaks in the washer tub and connected components. Check the installation of the drain system. Water can siphon out of the washer if it's not installed properly.
Outer tub, Hoses and components attached to the tub
Jun 18, 2015 | LG WM-2277HW Front Load Washer
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
OK I'm in deep trouble. I have an LG 2277h first I had the LE error and I read most of the posts. I unplugged and preformed QC test proceedures and then things went from bad to worse. My main problem...
Your going have to open it up. I think its the PWB ASSY, MAIN Part#6871ER1003C. Unscrew the top on the back and from the front push the top back. That will slide it back, it you see a red light on the power assembly then its not your problem but if its off then that is the part to replace. I'm ordering the part right now. Its pretty easy to unplug all the cables. I found it from 53 to 160 on the internets. You just have to shop around and call them to see if they actually have it in stock. http://media.fotki.com/1_p,ssbrgfbfrktqtddxgtqsskgwtqkq,vi/rwsbqgrbwxrqrkswwdq/1/1303472/5961857/image1927948615726646899img-or.jpg
Sep 30, 2010 | LG WM-2277HW Front Load Washer
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore top load washer machine
check that none of your hoses are blocked, by pulling the back cover off. If any of these hoses r blocked it will stop the washing machine from working same thing happened to me and thats how i fixed it
Jun 02, 2008 | Kenmore 80754 Top Load Stacked Washer /...
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG WM1812C Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
