My 4year old Bosch 800 front loader washing machine will not pump out water or spin after the first washing cycle, have cleaned filters? We live in the country at Meckering western australia, Can you help. Thank you Lorraine Roser lorraineroser@bordernet.com.au
  • sameday Aug 10, 2008
    Tha nks,
    We had already checked everything, so taking it to a Bosch Service Agent anyway,
  • 659 Answers
1 their is a coupling between the motor and the pump and this has finally worn out...2 on some models the pump is belt driven and the belt could be bad...3 on some models the pump is seperate from the drive motor and has its own motor just for the pump...this could be running but the pump part could be bad....even if it worked somewhat before that still does not mean the pump or the coupling that connects the pump to the motor wasnt going bad.....nearly all machines will allow the water to drain out if you just lower the drain hose lower than the tub...try letting the water drain into a small bucket and then see if it wil spin...it should spin once the water is drained out but you will have to keep the drain hose in the bucket lower than the tub through the spin cycle....this should work and allow you to get all the water out of your machine....dont use it anymore once you do this as you could damge other parts by trying to make it work...the parts and labor to fix this shouldnt be over 100 dollars
Posted on Aug 03, 2008
The machine does not respond to any programme. The spin selection display flashes the 800, 600 and rinse stop led's simultaniously. None of the buttons on the machine is responding when pressed or hel
If this is a front loader and there is a pump filter, pull it and clean it out. Mine is located on the front behind a small access door down by the floor. Be prepared for lots of water since your tub is probably full. If it can't pump the water out fast enough (filter plugged) it will become out of balance in the spin cycle and shut down. After you to this unplug the machine for 30 seconds, then plug back in to reset the electronics.
Jan 23, 2015 | Washing Machines
Smelly water & not going into spin
Try cleaning out the pump access port. It is at the front of the machine.
All sorts of stuff gets into these pumps on front loaders. A partial clog will go what you describe.
If you use a mesh laundry bag it will keep this from happening
Mar 23, 2014 | Bosch Washing Machines
My samsung front loader washing machine is not pumping or spinning says "error ND" checked pump all clear still nothing
on my kenmore machine nd means the drain filter is clogged. open the cover, drain water completely, remove and clean the filter, replace filter, tighten and close cover. hope this works for you. if not , at least your drain filter will be cleaned and you can eliminate it as the problem.
Feb 03, 2013 | Washing Machines
I have a Bosch clasixx 1200 s express washing machine, When I select a program the machine buzzes but the cycle doesn't begin. The drain cycle works and the spin works. if i select freshen and rinse the...
Bosch clasixx 1200 This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 26, 2011 | Bosch Classixx WFL 2066 Front Load Washer
My 3 year old front loader suddenly stopped draining, spinning, and now the door will not unlock. It still has power and you can hear clicking, it does cycle through wash, but stops at drain and lights...
This looks like the pump is blocked or drain or the pump has gone. to try and solve it best thing to do is open pump filter usually on bottom front of machine to access pump water will come out so be ready. when you have opened the filter you can check for a blockage and give it a clean put filter back on and put it on a cycle and see if it drains. to make door open start a cycle stop it after a few seconds of being on and turn off machine on machine not at plug and leave it for a while it should open. if it does not then switch off for 5 mins and back on and repeat it hope this helps.
Sep 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I have a bosch washer about 3 years old. It suddenly stopped on spin cycle and water would not drain even when I put it to drain only. The motor chatters now like a car with a battery that is dead. Is this...
It does sound like the problem is related to the water pump.
The filter should be located at the bottom front right of washer, sometimes behind a removeable cover.
Locate filter, and remove by turning anti-clockwise, and clean, check inside the filter housing for anything in there as well.
Hope this helps.
Nov 30, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Error Code EO6 - Bosch Front Loader WVT2850
Hi
I have have this same problem for 4 years now and engineers always told me it was becuase something may have been caught in the filter yet I clea my filter weekly and use the decaler they sold me on a monthly basis. Appartantly it is to do with the switch ??
Finally they have written my machine off yippee
Jun 25, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
