Question about Harbinger HP215 Powered Loudspeaker
Ran too much power through the speakers and I think I fried the crossovers. Can the crossover be replaced?
  • Harbinger Master
  • 5,603 Answers
This makes little sense... these are bi-amped speakers meaning the crossover is an electronic LOW LEVEL filter network. You can send LINE LEVEL signals to these (never the output of a power amplifier) and not damage the crossover electronics. You would normally connect the balanced line-level output of a mixer into these.
If you have connected a power amp into this by mistake, you likely blew the input circuit. You will have to have the circuitry replaced.
Very important is to connect ALL interconnected equipment to the same power source or receptacle. Powering speakers from one end of a venue and the mixer from the other end wall receptacles is a good way to blow circuitry due to ground bounce in buildings.
Give us more information of how you connected this AND also the symptoms... unless you are into electronics, self diagnosis of the problem may lead you astray as well as the technicians who fix it.
Posted on Mar 26, 2011
KRK Rokit monitor has no sound from bottom speaker (the larger speaker for lows and mids) the unit powers up fine and i get sound through the tweeter.
What you are describing is a total component failure of something in the crossover board. You cannot really check a crossover without an oscilloscope and a frequency generator. In a lot of cheap speaker systems, there is no crossover board attached to the woofer. In your case it appears that a low pass filter is present on the woofer. http://circuitdiagram.net/loudspeaker-system-crossover-network.html
Sep 27, 2015 | KRK RP5G2 Pair Rokit G2 Powered 2-way...
I have 2 peavey sp2 bx well I was pushing them really hard and blew the black widows. Now I have got a replacement and hooked it up and still no sound out of them. I do have the horns working but they...
The lamp bulb fusing is just on the horns. Check the Black Widows individually with an ohm meter for continuity. If the speakers themselves test OK, you most likely blew the crossovers. Peavey service (877-732-8391) can rebuild most of therir crossovers in house and they generally are cheaper to fix than replace.
Nov 02, 2014 | Music
My Mackie Thump TH-15A will not produce any bass. I can get some sound but only from the top tweeter. Whats wrong and how can i fix this?
Could be the crossover has died or the main speaker winding has failed. Open her up and connect on side of the main speaker direct to a 9v battery and then wipe the other wire over the other terminal. If you get a crackling from the speaker then it's likely the crossover, if there is no response at all from the speaker then it is dead and possibly the crossover too.
Sep 23, 2013 | Mackie TH-15A Active DJ Powered THUMP...
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 | Music
My pair of Peavy 118 unpowered subs quit working simultaneously. There was not any horrible noise or anything like that. They simply stopped working. I have a crossover and a biamped system that they...
I would NOT rewire them. The crossover is also part of the protection. The big question are the speakers themselves damaged? There may be a protection fues inside. There are also some resetable type fuses called "polyfuse" that sometimes fry and require replacement. This speaker is rated at 800 watts PEAK and 400 Watts program... that is NOT 400 watts continuous RMS... it is "specsmanship". You should be driving this with an amp capable of NOT MORE than 300 Watts.
They claim a SPL of 118 Db. That is loud, but if you used an amp capable of say 500 watts RMS you could easily blow the speaker. The crossover for this is likely a simple coil in series... possibly on a ferrite core. Hopefully if anything blew, it was the coil... but that is NOT likely. I assumed you have checked the amp as that would be the MOST probablle for a simultaneous failure of the subs.
May 14, 2011 | Peavey Pv118 1x18" Subwoofer Speaker...
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Alesis Monitor One crossover assembly removal?
The question is WHY would you replace the crossover network?
They seldom go bad... Usually the speakers aree blown before the crossover fails.
Jan 29, 2010 | Alesis Music
Harbinger HP215 Powered Loudspeaker Logo
155 people viewed this question
Top Harbinger Music Experts
Michial Gueffroy
Are you a Harbinger Music Expert? Answer questions, earn points and help others
