Question about Dryers
My whirlpool wed5550 dryer, when i try to turn it on it starts, but when i remove my finger from the button it stops...help
    Scholar:
  • 116 Answers
Hi this sounds like a broken belt, If this model doesnt have a belt switch then you could possibly have a bad centrifugal switch but is very rare, Probabably just need to replace the belt. Let me know if you need further assistance.
Sean
Posted on Mar 26, 2011
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
I have a quiet pak 2 Kenmore. When I depress the start button the drum works but there is no heat. I stops workin when I take my finger off the start button. Model 110.73932102
I looked up the model number. You have a 90 series dryer made by whirlpool. You need to take it apart and clean it up, cheack all limits and safetys for continuity. I beleive you have a bad motor If the drum turns and the belt is not broken when you release you button it stops that is either the start switch or the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2014 | Kenmore Dryers
It works very well get to a moment stops then you press button depart and goes but if you take your finger from depart button it stops again
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 17, 2011 | Dryers
When I press the start button to begin drying clothes, once you take your finger off the button nothing happens..The dryer drum will turn.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 26, 2011 | Whirlpool LGB6300 Gas Dryer
My whirlpool dryer wont continue to start when I remove my finger from start button
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dryer Repair ? The dryer will not start
heatman101
Sep 01, 2010 | Dryers
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
Whirlpool Electric Dryer wont turn on
Try this;
In your browser bar type in youtube.com
In the search box type in repairing whirlpool dryers
Then click on the apprpiate video.
This should help you.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Brand new dryer
try holding door switch down with your finger while pressing start button.if dryer starts then your door needs adjusting.
May 20, 2007 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
Marvin
Marvin
