Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
  • 552 Answers
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Posted on Mar 26, 2011
Frigidaire Gallery Professional Series GPD8998JC0 ... I can press the buttons to choose my settings but my START/CANCEL button won't work. So I try a 1 hour delay which works but then no water nor the...
Hi Joseph - I understand your dishwasher is displaying a "CL" error code. A "CL" code typically refers to the main door switch. The first easy troubleshooting tip is to flip the circuit breaker to the dishwasher for about 20 minutes and see if that resets it and clears the error. If the circuit breaker trick doesn't work, it could potentially mean that the door is not closed completely. However, it could also mean that the control board is not sensing that the door is properly closed. I would recommend checking the door switches. Look to see if you notice if anything is bent or misshapen. Also, you might try the manufacturer site to see if you can download an owner's manual for future reference. They typically have a large number of owner's manuals for consumer use. If you have tried these troubleshooting tips and still come up with a "CL" code, you might need to reach out to a local service tech who can better pinpoint the problem for you. Best of luck!
Dec 19, 2013 | Whirlpool GU2400XTP Built-in Dishwasher
All it says is Frigidaire gallery professional series
after turn on the stove for less than 5 minutes the smoke come out fronm the vent and smell burning
Feb 01, 2012 | Frigidaire FEF366 Electric Kitchen Range
My frigidaire gallery series dishwasher wont start and the lights are flashing. whats wrong?
I would cut the power to it for a full 5 minutes and see if it resets itself???????
Feb 10, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
My frigidaire dishwasher is blinking lights and a
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Jun 24, 2010 | Frigidaire Professional Series 24 in....
Hello! I have a Frigidaire (made by Electrolux) Gallery Professional Series gas range/electric oven, model #FGF379WJCA (manufactured in 1998). The appliance came with the house we moved into 2 years ago. ...
for question 1 the wire for the ignitor is bad has to be changed not an easy job if you can live with it itll be ok if not its best to call in a tech or take to repair shop not sure about question 2 sorry
Aug 30, 2009 | Electrolux Frigidaire Professional Series...
Dishwasher Frigidaire Professional Series model PDL4555RFC indicator is flashing Er and other words in red
The dishwasher is junk...poorly designed. Masterboard for electronic buttons keeps shorting out because the dishwasher vents from the top. have this dishwasher and know first hand. had it for about a year and its been fixed several times
Aug 07, 2009 | Frigidaire Professional Series 24 in....
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
i would check the warranty on the control board, if that is what the tech recommended. most mfg. cover electronics longer than the appliance itself.
it could also just be the keypad.
Apr 29, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
562 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
