Question about LG Refrigerators
The LG refrigerator door lights do not come on when I open the door every thing else works. French doors #LFC25760SW Hepl!!!
  • ds1718 Mar 26, 2011
    I tyested the bulbs,tested the switch, it all works. I get only 15 volts to the door switch' when I push the switch button and let it go thje lights blink , thats all I get .
    Scholar:
  • 116 Answers
Were the doors left open at anytime? If so it has a thermostat that will shut off the lights to keep from getting too hot, If they werent left open, could be bad bulb or stuck or bad light switch on the door, all very easy fixes.
Sean
Posted on Mar 26, 2011
  • Sean Miller Mar 26, 2011
    Ok a couple questions how exactly are you testing the voltage for 15 volts, there should be 2 switches not one since it is a french door, and if its blinking its possibly a bad switch, i believe this model runs power directly to the wall.
  • Leona Klajda
    Leona Klajda Jun 18, 2015
    Well,that's not exactly true. It has a digital switch on a 100 buck circuit board that cannot be reset manually. Broken drawers and shelves. I won't be buying another LG appliance. Poor quality for serious money. They had problems with the lights staying on because the doors don't always close. This was their fix. A board that blows if you don't close the doors in time.
I have a LG refrigerator w/french doors. We are trying to come up with a solution to slightly restrict how far the left door opens.
Add a stopper to hinge of door find the farthest you want door to open and add it to the pin just like they make for house doors
or strong braided cable attach to door bottom to center of bottom of ref size cable to how far you want door to open. a light spring can pull cable back to base of ref,
Jul 20, 2015 | LG LFX21976ST 3 Door French Door...
Lights go off and on
your sensor sw is deff call for a tech to replaced
Jan 12, 2014 | LG LFD22860 Bottom Freezer French Door...
Refrigerator lights blinking
my side by side door refrigerator Kenmore is indicating a red flashing light ( door open ) and nothing is preventing the door from closing
Jan 09, 2014 | LG LFD22860 Bottom Freezer French Door...
Refrigerator light not working before fail light started to blink when the door was opened - contacts on door switches OK - believe it to be poor contection - reading low voltage - looking for schematics...
If you have checked the light switch and found it to be working normally, then you will need to replace the control board because the light bulb is controlled by the relay switch. It is not directly connected to the light switch. Good luck
Jun 19, 2011 | LG LFD22860 Bottom Freezer French Door...
The freezer door pops open when the side by side doors are closed.
I have this problem with another French Door refrigerator. We just put a stool in front of the lower drawer to prevent it from opening when the upper doors are shut.
I know this may sound kind of like a simple idea, but it works without modifying the refrigerator.
Good luck on this.
Jan 19, 2011 | LG LFX25960ST Stainless Steel French Door...
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Nov 15, 2010 | LG LFX25975ST (247 cu ft) Side by Side...
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
My LG refrigerator is model LFC25760SW, double door, bottom freezer. When you close one door the other door opens slightly. I think the top latch has weakened. How can I repair this? Are new latches...
I'd look into the original owners manual that shows how to align the French doors when first purchased. Sounds like heavy usage, or it was improperly put on when you first got it. Try that first, re-align, and tighten the bolts. Last resort is replacing the latches, call the LG customer service center at 1 800 243-0000 for details.
Feb 05, 2010 | Refrigerators
LG LFC25760SB french door light off but hot
try to replace the bulb/ door switch
Nov 13, 2009 | Refrigerators
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
Refrigerators Logo
627 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
