Obviously blown capacitor. Black tar-like substance bulged out the side of either c6280 or c6279 ( can't tell because they are stuck together ) .Easy to replace if I knew what size the capacitor is
    President:
  • 1,623 Answers
The value of the capacitor will be written on the side of the actual capacitor thats blown. will say something like 2200uf 45v or something similar
Posted on Mar 26, 2011
  • Martin Murray Mar 26, 2011
    use a hair dryer to heat up the capacitor resin and gently peel it off and you will be able to read the values
  • 902 Answers
What model tv? take out the capacitor and bring it to radio shack im sure they can match it up easily for you if you cant read what it is
I get a double click when I turn on the set... The red light blinks with 5 seconds intervals. When on occasion when I turn it on and get one click the tv comes on but will black out about 15 to 20 minutes...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Aug 06, 2011 | Toshiba 55H70 55" Rear Projection...
TV keeps clicking on an off. No picture just black screen now.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
Hope this helps
Jun 14, 2011 | Samsung LN32A330 32 in. LCD TV
37 in vizio went black and made an alarm sound
Hi
Hope this helps
Jun 09, 2011 | Vizio Televison & Video
Loud Pop and the Screen went dead on a LG 42PX3DCV plasma TV. 5 years old so out of warrenty. I took the back off the tv and checked all the ceramic resistors and the resister on the Y-SUS board has...
Hi
Hope this helpout in solving the problem....
May 31, 2011 | LG 42PX3DCV 42 in. Plasma EDTV
It turns on Polaroid shows for a split second then makes a loud buzzing sound with black screen no volume nothing
Hi
Hope this help to solve the problem.
Sep 02, 2010 | Polaroid FLM-323B Television
While we are watching our TV it all of the sudden goes to black and white static with a horrible buzzing/fuzzy sound. If we turn it off and back on again it will be fine for a few mins. and then does it...
Hi
Hope this helps
Aug 11, 2010 | Televison & Video
Tv made a loud pop sound then the picture went bad. next mornting when turned on the tv has black stuff in it that slowling melted away then the picture was still bad
Hi
Hope this helps
Jun 19, 2010 | LG 42PX5D 42 in. Plasma HDTV
I have a knocking (5 quick, loud knocks) sound intermittently on my refrigerator. I think it is when the compressor starts up (not 100% sure). I opened the back panel and everything looked normal except...
Chances are that black tar like substance you are seeing if from the capacitor. This is were I would start, as a capacitor is not all that expensive. Make sure it is the same rating as the current capacitor, and be aware that capacitors store electricity. When you disconnect the leads don't cross the terminals with your fingers, or you will get a shock. Hope this helps
May 05, 2010 | Refrigerators
SUSPECT DAMAGED CAPACITORS
Bulged capacitors are blown, that is the reason why the motherboard do not start.
Sometimes replacing capacitor may fix the problem, but due to the inexpensiveness of motheboard, and to the chance that more component may had been damaged by the fault, when this happen you usually replace the motherboard, rather then repairing at component level.
Aug 09, 2009 | EliteGroup PM800M2 Motherboard
TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
