Question about Consew CN2230R Sewing Machine
Thread cutting Do you know if this model cuts the thread when your heel presses on the pedal?
    Problem Solver:
  • 6 Answers
If you are asking about the consew CN2230R , the answer is No ; it does not have a trimmer system.
Posted on Jan 02, 2009
I was attempting to pick up the bobbing thread, before sewing. The needle is now stuck in the down position and the handwheel is unresponsive but the motor is whirring when foot pedal is depressed.
Do not press the foot pedal. Continuing to run the motor when the machine cannot work properly could irreparably damage the motor. Unplug your machine. Cut the top thread at the needle, open the bobbin area and try to remove the bobbin case. You may have to patiently snip tangled threads, but eventually you should be able to get the bobbin case out. Once that happens, the needle will most likely be free.
Jun 22, 2017 | Sewing Machines
How do I start threading the overlocker
If it doesn't auto thread then...you cut the thread of the old spools near the spool itself and knot the new spool of thread to the cut ends. When all 3 or 4 threads are knotted to the old ends then you slowly hit the pressed foot to feed the knotted ends through until you reach the needles. Then you cut the knots and hand thread through each needle or feeder bar.
Nov 25, 2016 | Sewing Machines
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
How to adjust trimmer on tajima tumx
WIll need more information about what you are trying to adjust?
Machine functions a mechanical cut, but the thread wasn't cut?
Cutter has timing to be set or replace the fixed blade. are two basic possibilities. I need to know what it's doing cut wise? to know what to adjust.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 19, 2014 | Sewing Machines
How do I thread a bobbin on a brother ls 1520
You will run thread around the front peg that looks like a wheel in the front of the machine. There should be a graphic to tell you which way to go. thread the thread through a hole in your bobbin leaving out about 1/2 inch and put the bobbin on the small stub that will hold your bobbin while holding the thread. push it back while holding the thread tight press the pedal. Once the bobbin is full cut both strings.
Sep 11, 2014 | Brother Sewing Machines
Juki ddl 5550-6
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 07, 2013 | Juki DDL-8300
When I put the pedal down, the bobbin jams, and cuts the thread
try changing the needle
make sure the needle & thread & fabric are correct for each other
make sure ever thread guide is being used
try adjusting the top tension
Apr 01, 2012 | Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
How to put thread on a bobbin of a Kenmore Sewing machine
I could not find a guide for this model.
If there is a knob in the center of the handwheel, it needs to be loosened.
Take the thread from the spool around the first guide and then to toward the bobbin winder.
Run the end of the thread through an opening in the side of the bobbin spool.
Hold onto about 5" of the thread and place the bobbin spool onto the bobbin pin and move the pin to the right or the winding wheel to the left (depends on how your machine is designed).
Holding onto the thread end, press the power pedal.
When you cannot hold onto the thread any longer, stop the machine and cut off the thread end and then continue to wind the bobbin.
Disengage the bobbin winder (move the pin or the wheel back into place) and tighten the knob in the center of the handwheel before sewing.
Mar 24, 2010 | Kenmore 12912
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Consew CN2230R Sewing Machine Logo
64 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
